I want to make a video presentation
Diana Welz
#1 Post by Diana Welz » Wed Aug 16, 2017 12:47 am
Hi guys, I'm just wondering if anyone of you had already made a video presentation for their website? Some say that it is compatible and not compatible. I want to put a video on my website for better promotion.
Re: I want to make a video presentation
#2 Post by Woodstock » Wed Aug 16, 2017 2:33 am
MakeMKV is not going to be much help with that.
You will need to decide what "how compatible" you want to be, because there are several different "standards". The one based on MKV files is "WEBM" (see their home page at https://www.webmproject.org/ for more information), but it requires that the user have a WEBM-capable browser.
You may be better off creating your video, and having it hosted at a site that will take care of the compatibility issues for you.
Diana Welz
#3 Post by Diana Welz » Fri Aug 18, 2017 3:36 am
Woodstock wrote:MakeMKV is not going to be much help with that.
Thanks for the advice, I think I should follow it.
