Title information
Source file name: 00273.mpls
Duration: 1:29:54
Chapters count: 16
Segment count: 20
Segment map: 505,519,513,506,504,517,515,518,508,500,501,514,511,510,502,509,503,507,512,516
File name: The_Wall_t113.mkv
The Wall
Re: The Wall
Is that the retail version, redbox version, etc.?
Re: The Wall
drbuckingham wrote:Is that the retail version, redbox version, etc.?
I just rented the Redbox version and that seems to match for RedBox. Are the Retail and Redbox versions ever the same? I know that most of the time they are not.
Re: The Wall
Here is a good way to tell. If the main audio track is DTS-HD MA Surround 5.1 then both the Redbox and Retail versions will be the same.bretb wrote:drbuckingham wrote:Is that the retail version, redbox version, etc.?
If the main audio track is TrueHD 7.1 Atmos Surround 7.1 then the playlist for the respective version will be different. Reason being rental copies exclude the 7.1 track. I don't know if the same applies to DTS-HD MA Surround 7.1 but I would assume so.
Sorry for not posting the version since I assumed you guys knew. Hope this helps.
Re: The Wall
Thank you for the information. I will bear that in mind.
Re: The Wall
I know this was quite a while ago, but how did you determine 273 was the correct .mpls file? Makemkv 1.14.2 does not show an FPL entry or any indication at all. Watching the .mpls events through procmon on playback settles on 129.mpls.
Re: The Wall
There are 2 reliable methods that I use. The first is an application called Anydvd HD. The latest version will normally indicate the correct playlist using java detection. The second is manual detection. To do this, use Makemkv to make a backup of the blu-ray disc. Open the BDMV file and navigate to the STREAM folder. Inside the STREAM folder you will see the xxxxx.m2ts files. These are the segment files for the movie.
To determine the segments for the The Wall, let's use its sequence: 505,519,513,506,504,517,515,518,508,500,501,514,511,510,502,509,503,507,512,516
The first and last segments are the easiest to determine for obvious reasons (beginning credits in 505 and ending credits in 516). To ascertain what follows 505 take a peek at the last 45 seconds of 505 to see what the scene flows to next. In this case it goes to 519. You will see that the other segments do not flow from 505. You would keep doing this to sequence the movie in the correct order. You will find that the process should take no more than 30 minutes. Most scenes are pretty obvious on how they flow.
Once you have the segment map you can match up your sequence to the available sequences in Makemkv. This process should not take that long as well.
Try it and I hope this helps.
Re: The Wall
Thanks for the feedback...I'll take a look. It seems the manual process would be a bit tricky particularly for movies that jump around a lot, flashbacks, etc., but I'll certainly check it out as an alternate method.
