Re-Animator (Arrow Video Limited Edition)
stuckinkodiagain
Post by stuckinkodiagain » Mon Aug 14, 2017 7:18 am
Hello!
I'm having trouble creating MKV's from the new Arrow Video limited edition version of "Re-Animator," released on blu-ray on August 8, 2017. Both the "Unrated" and "Integral" versions of the movie (on two separate blu-ray discs) fail to copy without giving a specific error report.
I should note that my PC blu-ray drive works perfectly with other blu-ray discs, and that BOTH "Re-Animator" discs play perfectly on my separate blu-ray player. This is definitely not an issue with my drive, and the fact that both discs fail to copy (but play perfectly) leads me to believe this is a separate issue entirely.
Any help would be great!
Re: Re-Animator (Arrow Video Limited Edition)
Post by Woodstock » Mon Aug 14, 2017 12:42 pm
Activate debug logging (if you haven't already) and include the log in your reply (don't try attaching it, just put it in the message). The log itself will show more information than what appears in the log window.
Details in the FAQ in my signature.
stuckinkodiagain
Post by stuckinkodiagain » Mon Aug 14, 2017 3:29 pm
I can try and post more tonight, but with debug mode enabled, the errors I get within MakeMKV from the Integral version are:
DEBUG: Code 450 at 0K3q=&H9;9AV%g6eS~p:213136447
DEBUG: Code 0 at ~z,Qq`wKbmYLoYfejJ1y@:29399197
DEBUG: Code 0 at nm<^QIS|WwJyX^@Zc:213132675
DEBUG: Code 0 at nm<^QIS|WwJyX^@Zc:213132123
DEBUG: Code 0 at nm<^QIS|WwJyX^@Zc:121261980
LIBMKV_TRACE: Exception: Error in p->FetchFrames(2,true)
Failed to save title 6 to file /Re-Animator Integral Version (1985)/REANIMATOR_-_INTEGRAL_VERSION_t06.mkv
0 titles saved, 1 failed
Post by Woodstock » Mon Aug 14, 2017 5:59 pm
Mike will have to translate what the debug messages mean. This evening, follow the instructions in the FAQ and send the log and information files to support@makemkv.com for evaluation. Especially if the error seems to happen at the same point in multiple rips.
While it is possible this is something weird that needs to be addressed in MakeMKV, you might also try cleaning the disks. Yes, even if they're new. :) More and more disks seem to have chemicals used in packaging that migrate to the BD surface, and cause problems.
stuckinkodiagain
Post by stuckinkodiagain » Tue Aug 15, 2017 6:53 am
Woodstock,
Thanks again for your help. I've tried cleaning both discs, but no dice. I've e-mailed all the files and information you suggested to Mike... Hopefully something comes of it!
flatliner
Post by flatliner » Sat Aug 19, 2017 2:57 pm
I have the same problem with both versions can't rip them fails right away. Glad Im not the only one.
stuckinkodiagain
Post by stuckinkodiagain » Mon Aug 21, 2017 7:37 am
What's the word on this?
FrequencyBebop
Post by FrequencyBebop » Mon Aug 21, 2017 4:28 pm
I'm also having this problem.
donholio
Re: Re-Animator (Arrow Video Limited Edition) - Unrated Debu
Post by donholio » Thu Aug 24, 2017 10:01 am
I am also having this issue. Since we have the output from the Integral disc, I'm adding the Unrated Disk debug log:
Interestingly enough, all of the other titles on the disc rip without issue.
1st attempt with all audio types checked:
LPCM Mono
LPCM Stereo
DTS-HD MA 5.1
DTS-HD MA 5.1 Isolated Score
DD Stereo Commentary 1
DD Stereo Commentary 2
DD Stereo Commentary 3
PGS Subtitles
Saving 1 titles into directory C:/
DEBUG: Code 450 at }K_Q[.j|Xm')P@hZll":213136447
DEBUG: Code 0 at }K_Q[.j|Xm')P@hZll":213131180
DEBUG: Code 0 at }K_Q[.j|Xm')P@hZll":121262670
DEBUG: Code 0 at H42=at>$=j0#0bN4?o\u]:121267109
DEBUG: Code 0 at H42=at>$=j0#0bN4?o\u]:121267500
DEBUG: Code 0 at %R"HyeM$Rbd1@:5ZXZ4:29394459
DEBUG: Code 0 at %R"HyeM$Rbd1@:5ZXZ4:29396437
DEBUG: Code 0 at %R"HyeM$Rbd1@:5ZXZ4:213132376
DEBUG: Code 0 at %R"HyeM$Rbd1@:5ZXZ4:29398116
DEBUG: Code 0 at uaRHP>71QT$^}b!=:213130743
DEBUG: Code 0 at uaRHP>71QT$^}b!=:121262141
DEBUG: Code 0 at "|U'zPW2|nbfG*?:29396046
DEBUG: Code 1 at "(uZ6Iv_cq$QD?#t6;:121263498
DEBUG: Code 0 at "(uZ6Iv_cq$QD?#t6;:29395402
LIBMKV_TRACE: Specified conversion filter (68:A_PCM/INT/LIT->LPCMraw) is not available
DEBUG: Code 0 at "(uZ6Iv_cq$QD?#t6;:29397633
DEBUG: Code 0 at "(uZ6Iv_cq$QD?#t6;:121267914
DEBUG: Code 0 at "(uZ6Iv_cq$QD?#t6;:121269087
DEBUG: Code 0 at "(uZ6Iv_cq$QD?#t6;:213138195
Failed to save title 6 to file C:/REANIMATOR_-_UNRATED_VERSION_t06.mkv
I saw the conversion filter error there and unchecked the LPCM tracks leaving the following checked:
DTS-HD MA 5.1
PGS Subtitles
Here's the output from the rip without LPCM tracks:
DBG ASSERT: !2[&#\)Ta_S;1Z*St6d.S}c4I% at }K_Q[.j|Xm')P@hZll":213130467
DEBUG: Code 0 at }K_Q[.j|Xm')P@hZll":29396552
DEBUG: Code 0 at %R"HyeM$Rbd1@:5ZXZ4:213132882
LIBMKV_TRACE: Exception: bad track type
I have also cleaned the discs and verified there aren't any visible issues. I've tried with multiple readers (I use portable BR drives) -
BD-RE ASUS SBW-06C1S-U
BD-ROM MATSUSHITA BD-CMB UJ-120
BD-RE BUFFALO Optical Drive
All exhibit the same errors.
Post by Woodstock » Thu Aug 24, 2017 1:10 pm
I would suggest packaging up the debug log with the other information asked for in the FAQ link in my signature, and sending them to support@makemkv.com for Mike to look at. Debug messages have specific meanings to the program, but only he has the information to decode what they mean.
Strange that it would complain about the LPCM filter - is your profile asking that LPCM be converted to something else? I rip LPCM tracks on a regular basis, but I do not have any conversions being done.
donholio
Post by donholio » Thu Aug 24, 2017 3:25 pm
Woodstock wrote:I would suggest packaging up the debug log with the other information asked for in the FAQ link in my signature, and sending them to support@makemkv.com for Mike to look at. Debug messages have specific meanings to the program, but only he has the information to decode what they mean.
Sure
Woodstock wrote: Strange that it would complain about the LPCM filter - is your profile asking that LPCM be converted to something else? I rip LPCM tracks on a regular basis, but I do not have any conversions being done.
Nope. This is maybe the first time I've seen it. My profile is the default with a couple of added selections:
"-sel:all,+sel:(eng|nolang),-sel:core,-sel:havelossless,+sel:attachment"
donholio
Post by donholio » Thu Aug 24, 2017 3:33 pm
FYI, it's definitely not my disks. I was able to rip both with DVDFab HD Decrypter and I'm able to play the files with Media Player Classic.
Unfortunately even when I submit the disc image to MakeMKV after the fact, it knows it's an unencrypted disc but gives the same error. It looks like it's not an encryption issue.
stuckinkodiagain
Post by stuckinkodiagain » Tue Sep 05, 2017 8:01 pm
Not sure why the whole message board reverted to an older series of posts... But wanted to note to the powers-that-be that the new version off MakeMKV (1.10.7) does NOT fix this issue with "Re-Animator." I'm pretty sure that was also the case for user donholio, who also tried "Re-Animator" with the latest version of MakeMKV, with no luck.
Thanks again to the developer for your help!
stuckinkodiagain
Post by stuckinkodiagain » Sun Sep 10, 2017 12:16 pm
Hey guys, is there any update on the Arrow Video blu-ray release of "Re-Animator?"
Would love to know if a fix is in the works!
donholio
Post by donholio » Mon Sep 11, 2017 1:49 am
stuckinkodiagain wrote:Hey guys, is there any update on the Arrow Video blu-ray release of "Re-Animator?"
I received an email from support a few days ago. I provided them a couple of debug dumps they wanted from both discs. I'm hoping that means a fix is in the works.
If you need a solution now, there is at least one free blu-ray ripping solution out there. I used it to rip TS (container) files from the disk and used mkvtoolnix to re-containerize them into MKV files.
-Don
