trouble with Crazy Heart
tdtran1025
Post by tdtran1025 » Thu May 27, 2010 3:49 am
Shortly after the initial sequence, maybe about 300Mb worth, it stalls. The reading rate is 0.0x, and stays at this for a long time. I had to abort. What causes it, a new code?
Waiting for an answer...
Thank you
Re: trouble with Crazy Heart
Post by mike admin » Thu May 27, 2010 8:26 am
Please provide additional information per http://www.makemkv.com/faq/item/8/catid/6
Shadow2k
Post by Shadow2k » Thu May 27, 2010 10:15 pm
Does the .m2ts file name change before/after the stall happens? One of my discs showed a similar behavior whenever MakeMKV switched over to the next .m2ts file (Main feature was split into several .m2ts files).
The resulting MKV played fine though.
