Just wondering, are these a problem when ripping a bluray ISO ? or does MakeMKV fix them?
tia
and this from another ISO, but this one is all at "00:00:00"AV sync issue in stream 0 at 0:00:00.166 : video frame timecode differs by +66.733ms
AV sync issue in stream 0 at 0:00:00.233 : video frame timecode differs by +100.1ms
AV sync issue in stream 0 at 0:02:46.533 : video stream has 16 frames with invalid timecodes
AV sync issue in stream 0 at 0:00:00.200 : video frame timecode differs by +66.733ms
AV sync issue in stream 0 at 0:07:57.810 : video stream has 17 frames with invalid timecodes
AV sync issue in stream 1 at 0:00:00 : 0 frame(s) dropped to reduce audio skew to +4.666ms
AV sync issue in stream 2 at 0:00:00 : 0 frame(s) dropped to reduce audio skew to +4.666ms
AV sync issue in stream 3 at 0:00:00 : 0 frame(s) dropped to reduce audio skew to +18ms
AV sync issue in stream 4 at 0:00:00 : 0 frame(s) dropped to reduce audio skew to +26ms
AV sync issue in stream 5 at 0:00:00 : 0 frame(s) dropped to reduce audio skew to +26ms
AV sync issue in stream 1,2 at 0:00:00 with duration of 4.666ms : encountered overlapping frame, audio skew is +4.666ms
AV sync issue in stream 3 at 0:00:00 with duration of 18ms : encountered overlapping frame, audio skew is +18ms
AV sync issue in stream 4,5 at 0:00:00 with duration of 26ms : encountered overlapping frame, audio skew is +26ms
