Is this a successful rip?
pstnta
Post by pstnta » Thu Aug 10, 2017 12:01 pm
I just tested MakeMKV on linux and this is what the log looked like.
I highlighted the errors, I just want to know if they're related to the movie, or linux itself.
Debug log started at Thu Aug 10 11:49:46 2017 , written by MakeMKV v1.10.6 linux(x64-release)
001005:0000 MakeMKV v1.10.6 linux(x64-release) started
001004:0000 Debug logging enabled, log will be saved as /home/ch/MakeMKV_log.txt
001003:0020 DEBUG: Code 0 at G~~Z1`Sl:xS?^g_rlPoY 'f:29394160
001003:0020 DEBUG: Code 0 at no~Bt=HxXrTv3ak:121262279
005042:0000 The program can't find any usable optical drives.
003006:0000 Opening files on harddrive at /mnt/media/Downloads/extract/ahofv
003305:0000 AACS directory not present, assuming unencrypted disc
005053:0308 This functionality is shareware. You may evaluate it for 30 days after what you would need to purchase an activation key if you like the functionality. Do you want to start evaluation period now?
005050:0000 Evaluation version, 30 day(s) out of 30 remaining
003307:0000 File 00002.mpls was added as title #0
003307:0000 File 00019.mpls was added as title #1
003025:0000 Title #00021.m2ts has length of 70 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00015.m2ts was added as title #2
003025:0000 Title #00006.m2ts has length of 84 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00009.m2ts was added as title #3
003307:0000 File 00010.m2ts was added as title #4
003307:0000 File 00023.m2ts was added as title #5
003307:0000 File 00007.m2ts was added as title #6
003025:0000 Title #00001.m2ts has length of 25 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00000.m2ts has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00011.m2ts was added as title #7
003307:0000 File 00013.m2ts was added as title #8
003307:0000 File 00018.m2ts was added as title #9
003307:0000 File 00008.m2ts was added as title #10
003025:0000 Title #00022.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00012.m2ts was added as title #11
003307:0000 File 00014.m2ts was added as title #12
003025:0000 Title #00005.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00003.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00016.m2ts was added as title #13
001003:0020 DEBUG: Code 233 at eSY1Ko4vOzxXKDFlp9OKaPcJ:0
001003:0020 DEBUG: Code 233 at r5lexKuAweOADEUl4BvFaQQZ:0
001003:0020 DEBUG: Code 233 at cjFV2+YW39dhRednwpT9E5Qn:0
001003:0020 DEBUG: Code 233 at LwtDYdhp7SwTgfQoIXLfuvdi:0
005014:0000 Saving 1 titles into directory /mnt/home/ch
001003:0020 DEBUG: Code 0 at 'g1cU@r[v.UrDo~G/Mo4kaO:213130122
004001:0000 Forced subtitles track #6 turned out to be empty and was removed from output file
005005:0080 1 titles saved
005036:0104 Copy complete. 1 titles saved.
thanks!
Re: Is this a successful rip?
Post by d00zah » Thu Aug 10, 2017 12:33 pm
You appear to have 'Log debug messages' checked under 'General' preferences. Just clutter if you're not actually diagnosing a problem.
pstnta
Post by pstnta » Thu Aug 10, 2017 12:41 pm
d00zah wrote:You appear to have 'Log debug messages' checked under 'General' preferences. Just clutter if you're not actually diagnosing a problem.
ok thanks :)
Post by Woodstock » Thu Aug 10, 2017 2:28 pm
The important part is if the log says, "failed".
