Fatal Error Warning
Diana Welz
Fatal Error Warning
Post by Diana Welz » Wed Aug 09, 2017 4:53 am
hi. I just bought Black Swan on region B Blu-ray and whenever I try to rip it MakeMKV closes with a "Fatal Error" warning. I have no idea what copy protection may be on it as it doesn't let me get that far. it starts to try to read the disc then just crashes.
I'm using the latest build on Windows 7.
thanks in advance for any help
yorgo
Re: Fatal Error Warning
Post by yorgo » Wed Aug 09, 2017 12:11 pm
Can you post a copy of the error log? Need more info before making a better recommendation. Also, try cleaning the disc with mild soap and water then dry with a soft cloth (not paper towel).
Post by Woodstock » Wed Aug 09, 2017 6:35 pm
and if you can check the Windows Event Viewer for any crash reports there, it would help, too.
Diana Welz
Post by Diana Welz » Thu Aug 10, 2017 5:41 am
yorgo wrote:Can you post a copy of the error log? Need more info before making a better recommendation. Also, try cleaning the disc with mild soap and water then dry with a soft cloth (not paper towel).
I heard from other people before that cleaning the disc with mild soap will help, but, won't it damage the lens when I put the disc?
yorgo
Post by yorgo » Thu Aug 10, 2017 11:30 am
Not if you rinse thoroughly with water and towel dry...
Post by Woodstock » Thu Aug 10, 2017 2:27 pm
Most cleaning can be done with just a damp, SOFT towel, either cotton or microfiber. It should not take a lot of rubbing. You do not want a towel that is contaminated with ANYTHING abrasive, including dirt.
Personally, I have a bit more aggressive cleaning method - Pledge furniture polish, sprayed on lightly, rubbed in with a CLEAN finger, then a dry, soft cloth to remove the excess. Pledge doesn't use solvents that attack the disk, but it does remove fingerprints, the "haze" that sometimes contaminated new disks, and "filling in" MINOR scratches. It has the downside that, if you don't clean off the excess, it can contaminate your drive.
Diana Welz
Post by Diana Welz » Fri Aug 11, 2017 2:24 am
Woodstock wrote:Most cleaning can be done with just a damp, SOFT towel, either cotton or microfiber. It should not take a lot of rubbing. You do not want a towel that is contaminated with ANYTHING abrasive, including dirt.
Honestly, I did what you told me and guess what happened? It worked and I cannot believe it! Thanks buddy for the help! :lol:
