Disc Not inserted Blu-Rays
Bartleby191
Post by Bartleby191 » Tue Aug 08, 2017 6:14 am
So I am finding an issue where any Blu-Ray I put in isn't being "Found" It just says No disc Inserted
Anyone else seeing this issue?
Re: Disc Not inserted Blu-Rays
Post by Woodstock » Tue Aug 08, 2017 1:13 pm
Assuming this is a BD player (you haven't said what drive is involved), "No disk" is usually an issue with the operating system preventing access.
But there is not much to work from in your message.
Bartleby191
Post by Bartleby191 » Tue Aug 08, 2017 3:49 pm
Sorry yes, this is a Blu ray burner, that Works to burn DVDs and Has previously worked to Burn Blu-rays.... THis is a new issue.. I recently updated to V1.10.6 Because I couldn't get the newest Key to work with my older version...
Bartleby191
Post by Bartleby191 » Tue Aug 08, 2017 4:00 pm
Also I just Updated my Windows 10... Now that Im looking deeper into it Im pretty sure this is the issue that started this...
Post by Woodstock » Tue Aug 08, 2017 4:57 pm
Are you running MakeMKV with administrator privileges, or as a normal user?
Normally, if you can access DVDs, you should be able to access BDs. There are some operations that require higher privileges to do (key exchanges), but you would get error messages about that, rather than "no disk".
When this happens, can you read the disk with Windows Explorer? Or does Explorer say "Please insert a disk" when you click on the BD?
Smithcraft
Post by Smithcraft » Fri Aug 11, 2017 11:32 am
I had a similar issue, and it seems that sometimes the BD functions will fail.
Does your drive work with other programs when you use BD media? If not, you might need a replacement drive.
SC
