The Circle
snarkticon
The Circle
#1 Post by snarkticon » Sat Aug 05, 2017 2:17 pm
Hello, I've tried ripping The Circle several times, disc is clear of scratches and smudges. Here is the log:
Saving 1 titles into directory E:/Video/_THE_CIRCLE_A013
The source file '/VIDEO_TS/VTS_24_1.VOB' is corrupt or invalid at offset 5111910400, attempting to work around
The source file '/VIDEO_TS/VTS_24_1.VOB' is corrupt or invalid at offset 5112604672, attempting to work around
The source file '/VIDEO_TS/VTS_24_1.VOB' is corrupt or invalid at offset 5113298944, attempting to work around
AV synchronization issues were found in file 'E:/Video/_THE_CIRCLE_A013/title00.mkv' (title #1)
AV sync issue in stream 1 at 1:49:47.104 with duration of 819.478ms : audio gap - 25.608 missing frame(s)
The source file '/VIDEO_TS/VTS_24_1.VOB' is corrupt or invalid at offset 5113993216, attempting to work around
The source file '/VIDEO_TS/VTS_24_1.VOB' is corrupt or invalid at offset 5114687488, attempting to work around
The source file '/VIDEO_TS/VTS_24_1.VOB' is corrupt or invalid at offset 5115381760, attempting to work around
The source file '/VIDEO_TS/VTS_24_1.VOB' is corrupt or invalid at offset 5116076032, attempting to work around
AV sync issue in stream 0 at 1:49:52.118 : video frame timecode differs by +16.433ms
AV sync issue in stream 0 at 1:49:53.236 : video frame timecode differs by +16.427ms
AV sync issue in stream 1 at 1:49:53.660 with duration of 32ms : broken timecode, apparent audio skew is -208.711ms
The source file '/VIDEO_TS/VTS_24_1.VOB' is corrupt or invalid at offset 5116770304, attempting to work around
AV sync issue in stream 0 at 1:49:53.653 : video frame timecode differs by +32.855ms
AV sync issue in stream 0 at 1:49:54.771 : video frame timecode differs by +32.85ms
AV sync issue in stream 1 at 1:49:55.420 with duration of 32ms : broken timecode, apparent audio skew is -417.422ms
The source file '/VIDEO_TS/VTS_24_1.VOB' is corrupt or invalid at offset 5117464576, attempting to work around
AV sync issue in stream 0 at 1:49:55.188 : video frame timecode differs by +49.277ms
AV sync issue in stream 0 at 1:49:56.306 : video frame timecode differs by +49.272ms
AV sync issue in stream 1 at 1:49:57.180 with duration of 32ms : broken timecode, apparent audio skew is -626.133ms
The source file '/VIDEO_TS/VTS_24_1.VOB' is corrupt or invalid at offset 5118158848, attempting to work around
AV sync issue in stream 0 at 1:49:56.723 : video frame timecode differs by +65.7ms
The source file '/VIDEO_TS/VTS_24_1.VOB' is corrupt or invalid at offset 5118853120, attempting to work around
AV sync issue in stream 0 at 1:49:57.841 : video frame timecode differs by +65.694ms
AV sync issue in stream 1 at 1:49:58.940 with duration of 32ms : broken timecode, apparent audio skew is -834.844ms
AV sync issue in stream 0 at 1:49:58.258 : video frame timecode differs by +82.122ms
The source file '/VIDEO_TS/VTS_24_1.VOB' is corrupt or invalid at offset 5119547392, attempting to work around
AV sync issue in stream 0 at 1:49:59.376 : video frame timecode differs by +82.116ms
AV sync issue in stream 0 at 1:49:59.376 : too many video frames with invalid timecodes, future messages will be suppressed
AV sync issue in stream 1 at 1:50:00.700 with duration of 32ms : broken timecode, apparent audio skew is -1043.555ms
The source file '/VIDEO_TS/VTS_24_1.VOB' is corrupt or invalid at offset 5120241664, attempting to work around
AV sync issue in stream 1 at 1:50:02.460 with duration of 32ms : broken timecode, apparent audio skew is -1252.266ms
The source file '/VIDEO_TS/VTS_24_1.VOB' is corrupt or invalid at offset 5120935936, attempting to work around
AV sync issue in stream 1 at 1:50:04.220 with duration of 32ms : broken timecode, apparent audio skew is -1460.977ms
The source file '/VIDEO_TS/VTS_24_1.VOB' is corrupt or invalid at offset 5121630208, attempting to work around
The source file '/VIDEO_TS/VTS_24_1.VOB' is corrupt or invalid at offset 5122324480, attempting to work around
AV sync issue in stream 1 at 1:50:05.980 with duration of 32ms : broken timecode, apparent audio skew is -1669.688ms
The source file '/VIDEO_TS/VTS_24_1.VOB' is corrupt or invalid at offset 5123018752, attempting to work around
AV sync issue in stream 1 at 1:50:07.740 with duration of 32ms : broken timecode, apparent audio skew is -1878.4ms
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/VIDEO_TS/VTS_24_1.VOB' at offset '5123401728'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '5123401728'
AV sync issue in stream 1 at 1:50:09.500 with duration of 32ms : broken timecode, apparent audio skew is -2087.111ms
AV sync issue in stream 1 at 1:50:11.260 with duration of 32ms : broken timecode, apparent audio skew is -2295.822ms
AV sync issue in stream 1 at 1:50:13.020 with duration of 32ms : broken timecode, apparent audio skew is -2504.533ms
AV sync issue in stream 1 at 1:50:14.780 with duration of 32ms : broken timecode, apparent audio skew is -2713.244ms
Failed to save title 0 to file E:/Video/_THE_CIRCLE_A013/title00.mkv
Encountered 11 errors of type 'Read Error' - see http://www.makemkv.com/errors/dvdread/
0 titles saved, 1 failed
Re: The Circle
#2 Post by d00zah » Sat Aug 05, 2017 2:28 pm
Did you take a look at the link provided at the end of the log regarding DVD read errors? Damage to disc/mastering errors are not necessarily visible to the naked eye.
stone99
Re: The Circle
#3 Post by stone99 » Thu Aug 10, 2017 6:46 pm
probably not a scratch as I got the exact same result with a clean disc
Re: The Circle
#4 Post by d00zah » Thu Aug 10, 2017 7:27 pm
That was one option...
- a scratch - cleaning disc MAY help
- a mastering defect - try a different source disc. in the event of a bad lot, try a different retailer.
- structural protection - see below (the link I mentioned)
"Read error (DVD media)
On DVD media read error may be caused by several reasons. It can happen due to hardware failure - scratched disc, failing drive, or both. But it can also happen due to structure protection present on disc. Please verify that the disc is without apparent damage and your drive is working.
If you do believe that the reason for the failure is a structure protection then the easiest workaround is to open the DVD disc in manual mode per instructions at /manualdvd "
stone99
Re: The Circle
#5 Post by stone99 » Thu Aug 10, 2017 9:16 pm
I got success with the fourth title from the bottom
Title information
Source title ID: 25
Duration: 1:49:35
Chapters count: 17
Segment count: 1
Segment map: 2-18
File name: title12.mkv
tim909
Re: The Circle
#6 Post by tim909 » Wed Aug 16, 2017 8:46 am
I had problems as well with a disc that shouldn't have had any surface issues.
stone99 wrote:I got success with the fourth title from the bottom
Title information
Source title ID: 25
Duration: 1:49:35
Chapters count: 17
Segment count: 1
Segment map: 2-18
much thanks
toxicj
Re: The Circle
#7 Post by toxicj » Mon Oct 02, 2017 3:57 am
Title information
Source title ID: 25
Duration: 1:49:35
Chapters count: 17
Segment count: 1
Segment map: 2-18
That was the only title ID I could get to work also.
