MakeMKV 1.10.6 build on Debian 9 (Stretch) - FIXED
penguinmeister
Post by penguinmeister »
All,
Just as an FYI, the instructions for building MakeMKV 1.10.6 may not work on Debian 9 (Stretch) depending on what you already have installed.
The instructions don't install the zlib headers - so if they aren't already there then then the makemkv-oss "make" won't work.
To fix, add "zlib1g-dev" to the "sudo apt-get install ..." line as below:
sudo apt-get install build-essential pkg-config libc6-dev libssl-dev libexpat1-dev libavcodec-dev libgl1-mesa-dev libqt4-dev zlib1g-dev
Debian 9 (and other recent systems) now package the old "zlib" libraries as "zlib1g".
If you want to rebuild FFMPEG with AAC support then you will also need to install the AAC libraries before attempting to build FFMPEG:
sudo apt-get install libfdk-aac-dev libfdk-aac1
With these additions, MakeMKV works perfectly on Debian 9 (I'm using the KDE GUI).
16442496
Re: MakeMKV 1.10.6 build on Debian 9 (Stretch) - FIXED
Post by 16442496 »
Good info.
Yes, Debian 9 Stretch is asking to install zlib1g-dev.
This is what i use on my Debian 9 KDE to install Makemkv.
apt install build-essential pkg-config libc6-dev libssl-dev libexpat1-dev libavcodec-dev libgl1-mesa-dev zlib1g-dev qttools5-dev
Debian 13
Xfce 4.20
MakeMKV 1.18.2
MakeMKV 1.17.6 (Appimage)
2x Pioneer BD-ROM BDC-202
