Le Diner de cons 2017 remaster
pstnta
#1 Post by pstnta » Fri Aug 04, 2017 1:19 am
I'm trying to rip this disc but only the bonus features seem to work, the movie fails everytime.
here's my debug log, this version was released a few months ago, so I'm asumming it might be related ?
DEBUG: Code 2147483648 at nZw`nL[PA6p|d/S&:121265315
DAFD=PAAAADAAAAEABDQkEHwECAQ==
DCE=tsrllWJgbvSzuRSCJjv6fGzXOnYW7fS51btahuZ2QLLHvr0nD3Sn3VSUVEPG6Fn20xmKDVv/HmuabKN6z4Dka6OF2MUMyy8eiZzXsSehN1XehPTsjDHpTZyIsmDVxbJ11hi8KQwxvMK93poDB1MQa0pZpPUQ5EYy6Q==
DCE=IBktQUzHcTgFZGeB5NQ9HGj5AFv0eq9chZ3+ivSwjB4a62Ar/4si0rLDUWyqcLQQaXmsuxWkS+iEZyyHJXhn1CZzyCjPG8KxD8+XIhJv7nXjX7rG8sk+cP8eP4gHVU5HgRfFKoVqdKM4I9mdJfomy6Lq0LsKOLwIcw==
DISCID=FA2AD03437751712CA62AA9BEBDB3AD5F5599A3E
003307:0000 File 00001.mpls was added as title #0
003025:0000 Title #00001.m2ts has length of 99 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00002.m2ts was added as title #1
003307:0000 File 00003.m2ts was added as title #2
003307:0000 File 00004.m2ts was added as title #3
003307:0000 File 00005.m2ts was added as title #4
003307:0000 File 00006.m2ts was added as title #5
003025:0000 Title #00007.m2ts has length of 16 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00034.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00031.m2ts has length of 24 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00035.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00037.m2ts has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00040.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00041.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
005014:0000 Saving 1 titles into directory C:/New folder/Le_Dîner_de_cons
001003:0020 DEBUG: Code 45048000 at }K_Q[.j|Xm')P@hZll":213134170
001003:0020 DEBUG: Code 0 at H42=at>$=j0#0bN4?o\u]:29399197
005003:0000 Failed to save title 0 to file C:/New folder/Le_Dîner_de_cons/Le_Dîner_de_cons_t00.mkv
005004:0080 0 titles saved, 1 failed
Application exited at Fri Aug 04 01:01:53 2017
any ideas ?
thanks!!
Re: Le Diner de cons 2017 remaster
#2 Post by Woodstock » Fri Aug 04, 2017 1:49 am
I would suggest following the FAQ link in my signature and submitting the files to support@makemkv.com, AFTER you try cleaning the disk.
The debug messages are consistent with the drive reporting unexpected data, which usually is because it is having an issue reading the disk. Most drives will report a read error, but some just send back their "best guess" at the data.
pstnta
#3 Post by pstnta » Fri Aug 04, 2017 3:37 am
Woodstock wrote:I would suggest following the FAQ link in my signature and submitting the files to support@makemkv.com, AFTER you try cleaning the disk.
Ok I will, for the record, the disc is brand new.
#4 Post by Woodstock » Fri Aug 04, 2017 5:11 am
And, for the record, "brand new" means nothing when dealing with optical media.
Disks can be contaminated (and damaged physically) while still sealed in their packages. Blu-ray is far less tolerant of shipping abuse and packaging chemicals than DVD.
I know this from personal experience.
