Display height and width not applying.
crookedmind
#1 Post by crookedmind » Wed Aug 02, 2017 11:37 am
( changing mkv display doesn't change it )
So, I have this file with the following media info:
Width                             : 670 pixels
Height                            : 574 pixels
Display aspect ratio               : 5:3
Original display aspect ratio      : 5:3
edit*
These are PAL res which are/are not upscaled.
Re: Display height and width not applying.
#2 Post by Woodstock » Wed Aug 02, 2017 2:17 pm
There are two places in an MKV file that the aspect ratio can be found - one of the headers (which you're trying to edit) and in the video stream itself. They're supposed to match.
Which one is used depends on your player - some read the stream, others look at the header. Which is why they should match....
crookedmind
#3 Post by crookedmind » Wed Aug 02, 2017 11:59 pm
[quote="Woodstock"][/quote]
I'm not sure you understand what I wrote.
#4 Post by Woodstock » Thu Aug 03, 2017 1:21 am
You're editing the header only, correct? Because MakeMKV isn't going to change what's in the video stream, and I don't think mkvtoolnix does that, either.
However, if I edit the headers of something I've encoded, ...
If you're re-encoding the video, then it is important that the encoding program gets the correct aspect ratio. I've found that handbrake gets the correct aspect ratio even when the header value is screwed up, because it reads the video stream. It then sets the header on the output file to match what it encoded.
crookedmind
#5 Post by crookedmind » Thu Aug 03, 2017 1:29 am
Woodstock wrote:You're editing the header only, correct? Because MakeMKV isn't going to change what's in the video stream, and I don't think mkvtoolnix does that, either.
crookedmind
#6 Post by crookedmind » Sat Aug 05, 2017 8:57 am
Edit*
See first post. You can delete this thread.
