The Circle
The Circle
Multiple selections for backing up "The Circle" any suggestions?
Re: The Circle
I am going to work on it today to see if I can figure it out. I hate there isnt a clear cut way for this. Process monitor didnt work for me on the last couple of them
Re: The Circle
Playlist 00318.mplsbook1 wrote:Multiple selections for backing up "The Circle" any suggestions?
Re: The Circle
hvnphoto wrote:Playlist 00318.mplsbook1 wrote:Multiple selections for backing up "The Circle" any suggestions?
Can you tell me how you got that? I didnt get that with the process monitor. I would love to know for the future
Re: The Circle
I manually completed the segment map. AnydvdHD yielded the same result.JediSamReye wrote:hvnphoto wrote:Playlist 00318.mplsbook1 wrote:Multiple selections for backing up "The Circle" any suggestions?
Re: The Circle
I manually completed the segment map. AnydvdHD yielded the same result.[/quote]
Awesome thank you! I wish i knew how to do that
Re: The Circle
If you install Java on your system, MakeMKV is pretty good about selecting the correct movie feature for you.
See example for "The Circle" which I just rented from RedBox, below:
Re: The Circle
It took me forever to get Java linked to MakeMKV on my iMac. Turns out I had to go into Java in the macOS preferences setting to get the path. But now it works nicely.
