The Circle
book1
The Circle
Post by book1 » Tue Aug 01, 2017 5:28 am
Multiple selections for backing up "The Circle" any suggestions?
JediSamReye
Re: The Circle
Post by JediSamReye » Tue Aug 01, 2017 3:52 pm
I am going to work on it today to see if I can figure it out. I hate there isnt a clear cut way for this. Process monitor didnt work for me on the last couple of them
hvnphoto
Re: The Circle
Post by hvnphoto » Tue Aug 01, 2017 3:52 pm
book1 wrote:Multiple selections for backing up "The Circle" any suggestions?
Playlist 00318.mpls
JediSamReye
Re: The Circle
Post by JediSamReye » Tue Aug 01, 2017 4:39 pm
Playlist 00318.mpls
Can you tell me how you got that? I didnt get that with the process monitor. I would love to know for the future
hvnphoto
Re: The Circle
Post by hvnphoto » Tue Aug 01, 2017 4:42 pm
JediSamReye wrote:
Playlist 00318.mpls
I manually completed the segment map. AnydvdHD yielded the same result.
JediSamReye
Re: The Circle
Post by JediSamReye » Tue Aug 01, 2017 5:07 pm
I manually completed the segment map. AnydvdHD yielded the same result.[/quote]
Awesome thank you! I wish i knew how to do that
bretb
Re: The Circle
Post by bretb » Tue Aug 01, 2017 11:00 pm
If you install Java on your system, MakeMKV is pretty good about selecting the correct movie feature for you.
See example for "The Circle" which I just rented from RedBox, below:
KENSAI
Re: The Circle
Post by KENSAI » Wed Aug 02, 2017 12:24 am
It took me forever to get Java linked to MakeMKV on my iMac. Turns out I had to go into Java in the macOS preferences setting to get the path. But now it works nicely. :D
