macos high sierra
DJRumpy
Re: macos high sierra
#16 Post by DJRumpy » Wed Jul 26, 2017 3:42 pm
Updated to Beta 3 this morning. Same issues exists with the latest beta.
Moonloop
#17 Post by Moonloop » Mon Jul 31, 2017 7:16 pm
Same problem here on Public Beta 3. 'Program has encountered a fatal error' !! Doesn't sound too good .
Hopefully sorted soon
~M~
#18 Post by mike admin » Mon Jul 31, 2017 7:21 pm
This is bug in MakeMKV, not Apple FS or anything like that. Apple is evil, but not this time. The bug is fixed, the next version should be released soon. It will be 64-bit only, still 10.6 compatible but requires x64 CPU. The 10.6 is the last version one can run on 32-bit machine.
DJRumpy
#19 Post by DJRumpy » Mon Jul 31, 2017 7:28 pm
Lol..I just downgraded this morning to allow me to continue using my software. Ah well. I'll keep on mac on the release version and one on beta. Good to hear in any case.
Thanks again Mike!
asr101
#20 Post by asr101 » Mon Jul 31, 2017 9:29 pm
Thats Awesome news Mike. Thanks.
DrBob
#21 Post by DrBob » Tue Aug 08, 2017 8:43 pm
mike admin wrote:This is bug in MakeMKV, not Apple FS or anything like that. Apple is evil, but not this time. The bug is fixed, the next version should be released soon. It will be 64-bit only, still 10.6 compatible but requires x64 CPU. The 10.6 is the last version one can run on 32-bit machine.
Its fixed in Beta 4, for me. So it turned out to be a bug in High Sierra and not related to APFS.
mymkv
#22 Post by mymkv » Wed Aug 09, 2017 10:27 am
hello.
After Beta 5 (17A330h) it seems 1.10.6 is working fine!!!!!!!!!!!!!
fantastic :-)
mechanic57
#23 Post by mechanic57 » Wed Aug 09, 2017 12:42 pm
The latest update to High Sierra Beta(10.13 Beta (17A330h) fixes issue. tested today 09/08/2017 12:41GMT
mymkv
#24 Post by mymkv » Fri Sep 15, 2017 8:21 pm
high sierra golden master: makemkv is still working 8)
User18
#25 Post by User18 » Sat Sep 30, 2017 8:59 pm
I've recently upgraded my Macbook to High Sierra official release and MakeMKV 1.10.7 doesn't detect my USB-connected Samsung SE-506 BD drive. Any input would be welcome.
This is the output I get from MakeMKV:
MakeMKV v1.10.7 darwin(x64-release) started
The program can't find any usable optical drives.
#26 Post by Woodstock » Sat Sep 30, 2017 9:41 pm
The issue is that, when MakeMKV asked the computer, "list optical drives", MacOS said "there are none".
You can try unplugging the drive, plugging it back in, then starting MakeMKV again (it only asks on start-up). This resets the interface between MacOS and the drive, which USUALLY fixes this problem (also does it in Windows, most of the time).
DavidHOO
#27 Post by DavidHOO » Mon Nov 27, 2017 9:07 am
MakeMKV can't work on my macOS High Sierra, so I want to try Pavtube, which claims that it is the best MakeMKV alternative.
#28 Post by Woodstock » Mon Nov 27, 2017 1:40 pm
DavidHOO, you're bound and determined to sell PavTube, aren't you?
Every message you've posted since you joined this forum is "MakeMKV can't do what PavTube does", even though PavTube started as a pirated version of MakeMKV. And when asked about whether or not they'd fixed that 'little issue', you've ignored the question.
There are a number of people here running MakeMKV on High Sierra, so you're issue is isolated.
