I'm trying to rip the DVD version (Redbox) of Power Rangers. I need Title #32 which says that it was added, but the list stops on title #27 (there should be a 28, 29, 30, 31, and 32 as shown in the logs). Any idea why?
This is on the Mac version, but I'm going to try to boot into Windows and try again.
Log says Title was added, but doesn't appear in the list
DrieStone
DrieStone
Re: Log says Title was added, but doesn't appear in the list
I tried in Windows with the same result.
Can you post the log from the scan? Don't try to attach it - just click the "Code" button above the reply box, and paste the contents of the log in between the tags.
(assuming you've got debug logging turned on, as described in the FAQ link in my signature)
Theodred
I'm seeing the same as OP.
Here's my log:
Here's my log:
MakeMKV v1.10.6 darwin(x86-release) started
Debug logging enabled, log will be saved as /Users/Erik/MakeMKV_log.txt
Optical drive "DVD+R-DL HL-DT-ST DVDRW GA32N KE06d" opened in OS access mode.
Title #1 was added (18 cell(s), 2:03:46)
Title #2 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #3 has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #4 has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #5 has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #6 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #7 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #8 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #9 has length of 94 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #10 has length of 40 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #11 has length of 40 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #12 has length of 81 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #13 has length of 68 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #14 has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #16 has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #19 was added (18 cell(s), 2:03:46)
Cells 2-4 were skipped due to cell commands (structure protection?)
Title #20 was added (17 cell(s), 2:00:47)
DEBUG: Code 10551300 at 4p=DFU5Op@P9{1bo:29405752
DEBUG: Code 0 at 4p=DFU5Op@P9{1bo:29406741
DEBUG: Code 0 at Fp!`s[eu;>p=?(j2u/:29394229
CellWalk algorithm failed (structure protection is too tough?), trying CellTrim algorithm
Cells 1-1 were removed from title start
Cells 19-19 were removed from title end
Title #21 was added (17 cell(s), 2:03:43)
Title #24 was added (17 cell(s), 2:03:43)
Title #25 was added (19 cell(s), 2:04:46)
Title #26 was added (19 cell(s), 2:04:51)
Title #27 was added (19 cell(s), 2:04:54)
Title #28 was added (17 cell(s), 2:03:43)
Title #29 was added (17 cell(s), 2:03:43)
Title #30 was added (18 cell(s), 2:03:46)
Title #31 was added (18 cell(s), 2:03:46)
Title #32 was added (17 cell(s), 2:03:43)
Title 1 in VTS 23 is equal to title 1 and was skipped
Title 1 in VTS 16 is equal to title 1 and was skipped
DEBUG: Code 233 at 5QpX3o7sLcpjEOqOg2zgZGvm:0
Operation successfully completed-
diy_darryl
Same issue here, VLC Media Player selects title 32 as the correct title for Power Rangers DVD and makemkv adds that title but it doesn't show up as a selection. Title 21 has the same exact playtime of 2:03:43 so I chose it, watched the movie and it is the correct version.
insub
Thank you, Darryl!diy_darryl wrote:Same issue here, VLC Media Player selects title 32 as the correct title for Power Rangers DVD and makemkv adds that title but it doesn't show up as a selection. Title 21 has the same exact playtime of 2:03:43 so I chose it, watched the movie and it is the correct version.
