MakeMKV v1.10.5
This disc uses newer version of AACS protection
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command
Anyone else see this?
Kong Skull Island
outdoorguy568
Re: Kong Skull Island
Did you try the most current version.... v1.10.6?dare7ab wrote:MakeMKV v1.10.5
dare7ab
Yes - the latest version (v1.10.6) solved the problem.
reol09
Yup. Same issue here. Any fix for this kind of error? I am using 1.10.6
outdoorguy568
I'm using the same version (v1.10.6) and had no issues. Make sure you have "Allow contacting web server for updates" checked off under "View" then "Preferences" then the "General" tab.reol09 wrote:Yup. Same issue here. Any fix for this kind of error? I am using 1.10.6
WAYFLIX
Worked just fine for me too.outdoorguy568 wrote:I'm using the same version (v1.10.6) and had no issues. Make sure you have "Allow contacting web server for updates" checked off under "View" then "Preferences" then the "General" tab.reol09 wrote:Yup. Same issue here. Any fix for this kind of error? I am using 1.10.6
