I recently had to wipe my C drive and reinstall windows. I was running a paid version of makemkv but upon reinstall it has reverted back to evaluation version. Is there a way to reactivate the paid version or do I have to purchase it again?
Thank you.
Wiped computer, makemkv now says 'evaluation version'?
poptop69
Re: Wiped computer, makemkv now says 'evaluation version'?
Help > Register . Paste in reg code. OK
And if you didn't record your registration code, check your email for a message from "avangate.com"; that's the company that processes payments and issues the registration code.
Failing that, contact support@makemkv.com with your information (email address used when you bought it, etc.), and Mike can look up your registration code.
poptop69
Thank you both for your help!! I had forgotten that the email came from avangate. We're up and running again!
