The Assignment (2016)
hvnphoto
Post by hvnphoto »
Title information
Name: The Assignment
Source file name: 00781.mpls
Duration: 1:34:50
Chapters count: 16
Segment count: 20
Segment map: 507,512,510,511,504,516,500,501,502,509,505,513,515,508,517,506,518,503,514,519
File name: The_Assignment_t321.mkv
ekael86
Re: The Assignment (2016)
Post by ekael86 »
Thanks for posting this! Much Appreciated.
q3131a
Post by q3131a »
Check that MakeMKV didn't move it to the top - one of the characteristics of MakeMKV finding the "main title" is that it will be one of the first ones listed.
Cobalt
Post by Cobalt »
Woodstock wrote:Check that MakeMKV didn't move it to the top - one of the characteristics of MakeMKV finding the "main title" is that it will be one of the first ones listed.
I thought that and assumed that title 00 was the one to rip. Imagine my surprise when watching the mkv file to find scenes jumbled up.
What is up with all these mpls files? Is it some kind of extra DRM?
Thanks to hvnphoto for the info on the correct file to rip.
Jack the DB Ripper
Post by Jack the DB Ripper »
For me, the title that matches the OP's source file / segment map is 322, not 321
Anyone know why?
Radiocomms237
Post by Radiocomms237 »
Just looking at this disc now and I've found 00781.mpls as outlined above with the correct segment map (also appears as t322 on my disc), but...
There seems to be two versions of the movie on the disc, the one above (and all it's jumbled-up counterparts) is 23.3GB with a duration of 01:34:50
But there seems to be another version of 21.4GB with a duration of 01:24:30 (with only 19 segments instead of 20).
Unfortunately there are hundreds of playlists for this version as well with the segments all jumbled, so how do I know which is the correct one for this shorter version of the movie?
Or is this "shorter version" yet another attempt to confuse me?
