[SOLVED] build 797: Timecode delay out of tolerance?
ChinaJade
Post by ChinaJade »
Using: Extracting "Star Wars IV: A New Hope" straight from the DVD yields the following error ("Log Debug Messages" was checked on):
Cell 39 was discarded (structure protection?)
Cell 71 was discarded (structure protection?)
Complex multiplex encountered - 2 cells and 636 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
Navigation information for Vobu 112839 conflicts with cell 2 playback information. Using cell information. (structure protection?)
Title #0 was added (65 cell(s), 2:04:09)
Complex multiplex encountered - 2 cells and 635 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
Navigation information for Vobu 113396 conflicts with cell 3 playback information. Using cell information. (structure protection?)
Angle #2 was added for title #0
Complex multiplex encountered - 2 cells and 634 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
Navigation information for Vobu 113992 conflicts with cell 4 playback information. Using cell information. (structure protection?)
Angle #3 was added for title #0
Title #1 has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #2 has length of 27 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #3 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #4 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #5 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #6 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #7 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #8 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #9 with special attributes was skipped
Title #10 with special attributes was skipped
Title #11 has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #12 has length of 62 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #13 has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #14 has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #15 has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Operation sucessfully completed
Saving 1 titles into directory V:/MKV
LIBMKV_TRACE: Exception: MKV_ASSERT: TimecodeDelay >= int16(0x8000) && TimecodeDelay <= int16(0x7FFF)
Failed to save title 0 to file V:/MKV/title00.mkv
0 titles saved, 1 failed
I had AnyDVD running at the time. Turned it off, tried again, and same result. The disc also had the same problem when tried on a Matshita drive.
No complaints, just reporting an issue if you get time to look at it.
Edit 9-Apr-2009: [SOLVED] Confirmed that 1.4.0 beta addresses the problem with this problematical disc. Also, thank you for making File -> Open Files return to the most-recently used directory. It looks like some performance improvements made it into this release too. You guys are the best!
skufft
Re: build 797: Timecode delay out of tolerance?
Post by skufft »
I have experienced the same error with the same DVD, on both my LITE-ON drive and the drive in my Dell laptop. I believe Rambo and Forgetting Sarah Marshall experienced this as well. I was able to rip just the movie from the DVDs of Rambo/FSM on DVDFab and those resulting files compiled fine in MakeMKV. The same solution did not work for A New Hope however. A New Hope did work fine in mkvmerge.
Other than those few DVDs, the program has been great!
edit: I wanted to note that mkvmerge does not preserve subtitles, chapters, or even sync audio as effortlessly as MakeMKV, so I would much prefer to use that!
Post by mike admin »
The cause is known and we are working on this - the next version should have this error corrected. Stay tuned :)
This is corrected in the latest version (1.4.0).
bitbuerster
Post by bitbuerster »
mike admin wrote:This is corrected in the latest version (1.4.0).
As I wrote in another thread, I have the very same timecode-problem with BD "Black Hawk Down". Could you tell a bit what this strange error message causes?
tnx
Re: [SOLVED] build 797: Timecode delay out of tolerance?
This is an error produced my MKV multiplexer. The latest version (1.4.8) has a fix to what may be a cuase for this error. Please try 1.4.8 and post results here.
bitbuerster
mike admin wrote:This is an error produced my MKV multiplexer. The latest version (1.4.8) has a fix to what may be a cuase for this error. Please try 1.4.8 and post results here.
Well, thanks for the information. I gave it a try with the new 1.4.8 (upon the rip on the HD, made by AnyDVD HD): Behavior is as before, same "timecode" error as before:
MakeMKV v1.4.8 beta win(x86-release) started
Debug logging enabled, log will be saved as C:\Users\kr/MakeMKV_log.txt
FAILURE: Code 3221225488 at `O>x,Je3*7/w%s:213130927
FAILURE: Code 3221225488 at dSxz^+8VEkv' -.':121263061
FAILURE: Code 0 at dSxz^+8VEkv' -.':121262762
FAILURE: Code 0 at 4sa,n4KrKusRVFPXBpq1+:2CTF:29393516
The program can't find any usable optical drives.
Opening files on harddrive at C:/Video/57760311_BLACK_HAWK_DOWN/
AACS directory not present, assuming unencrypted disc
File 00009.mpls was added as title #0
Title #00023.mpls has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00025.mpls was added as title #1
Title 00035.mpls is equal to title 00009.mpls and was skipped
File 00042.mpls was added as title #2
File 00002.m2ts was added as title #3
File 00003.m2ts was added as title #4
File 00004.m2ts was added as title #5
File 00005.m2ts was added as title #6
File 00006.m2ts was added as title #7
Title #00009.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00010.m2ts has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00011.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00012.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00013.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00014.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00015.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00016.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00017.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00018.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00019.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00020.m2ts has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00021.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00022.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00027.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00028.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00029.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00030.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00031.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00032.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00033.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00034.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00035.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00036.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00037.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00040.m2ts has length of 17 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 1 titles into directory C:/Video/UNNAMED_DISC
Failed to save title 0 to file C:/Video/UNNAMED_DISC/title00.mkv
If you have another idea what to try else, I'll try it out..
