Internal error: openssl test 00FC failed
rxguy
#1 Post by rxguy » Sun Apr 16, 2017 1:42 am
I get this error on start up.
Running Fedora Rawhide.
openssl-1.1.0e
When I try to open a bluray, I get:
DEBUG: Code 0 at _B,194!,~NL]?7c&:121263935
DEBUG: Code 0 at _B,194!,~NL]?7c&:121265844
DEBUG: Code 233 at wAgpLwOFt4x3y+lb3mZdSsON:0
DEBUG: Code 233 at QprhZvlkmQj2+z2hWvAWkrv+:0
DEBUG: Code 233 at 9tBUSuZnAExamS+P2W+TgBC3:0
DEBUG: Code 233 at MDnVN8pVYt1MmTRXeU7Awfps:0
Thanks.
Re: Internal error: openssl test 00FC failed
#2 Post by Woodstock » Sun Apr 16, 2017 4:00 pm
"Volume key unknown" errors are usually traceable to being unable to read parts of the directory structure of the disk. Were there errors prior to that line?
rxguy
#3 Post by rxguy » Sun Apr 16, 2017 7:26 pm
This is the entire log file:
Debug log started at Sun Apr 16 01:32:59 2017 , written by MakeMKV v1.10.5 linux(x64-release)
001005:0000 MakeMKV v1.10.5 linux(x64-release) started
001004:0000 Debug logging enabled, log will be saved as /home/dturner/MakeMKV_log.txt
001010:0000 Internal error: openssl test 00FC failed
001003:0020 DEBUG: Code 0 at R&AW69*m$W0vCyK7wTOp-5N:213130122
005053:0308 This functionality is shareware. You may evaluate it for 30 days after what you would need to purchase an activation key if you like the functionality. Do you want to start evaluation period now?
005050:0000 Evaluation version, 30 day(s) out of 30 remaining
DEBUG: Code 2147483648 at {gxa-U)_kSl4hJj<:121265315
DAFD=PAAAADAAAAEABDQkEHwEBAQ==
001003:0020 DEBUG: Code 0 at s~VsbH+VjYn8<PUH87:213130789
003341:0000 Highest AACS version is v14 , MKB saved as /home/dturner/.MakeMKV/MKB_v14_GIJOE_AC.tgz
003303:0000 The volume key is unknown for this disc - video can't be decrypted
001003:0020 DEBUG: Code 0 at _B,194!,~NL]?7c&:121263935
001003:0020 DEBUG: Code 0 at _B,194!,~NL]?7c&:121265844
001003:0020 DEBUG: Code 233 at wAgpLwOFt4x3y+lb3mZdSsON:0
001003:0020 DEBUG: Code 233 at QprhZvlkmQj2+z2hWvAWkrv+:0
001003:0020 DEBUG: Code 233 at 9tBUSuZnAExamS+P2W+TgBC3:0
001003:0020 DEBUG: Code 233 at MDnVN8pVYt1MmTRXeU7Awfps:0
Application exited at Sun Apr 16 01:58:09 2017
Thanks.
sam302psu
#4 Post by sam302psu » Fri Jun 09, 2017 5:28 pm
I get this error:
MakeMKV v1.10.6 linux(x64-release) started
Debug logging enabled, log will be saved as /home/sam/MakeMKV_log.txt
Evaluation version, 25 day(s) out of 30 remaining
DEBUG: Code 0 at W~ZA$vK;|{n10c S[O:213130789
Highest AACS version is v56 , MKB saved as /home/sam/.MakeMKV/MKB_v56_INSIDE_OUT.tgz
DEBUG: Code 0 at ,M1{q3WO9x`>\1E5:29396046
DEBUG: Code 0 at ,M1{q3WO9x`>\1E5:213134009
Any thoughts on how to fix?
brendan
#5 Post by brendan » Sat Jun 24, 2017 2:35 am
I also have this error.
Until today I was using 1.10.6 on Debian Stretch with no issues.
Today I moved to Fedora 26, and have come across the "openssl test 00FC failed" error.
I have (in the last hour), downloaded the latest 1.10.6 code, and compiled from scratch on a clean system.
The issue seems confined to Bluray disks. I tried 4 BD's (of varying ages) and all failed to read. I have tried 4 DVD's (also of varying ages) and they can all be read as expected.
FYI
openssl version
returns
OpenSSL 1.1.0f-fips  25 May 2017
This was my compile/install script:
sudo dnf install kernel-devel gcc-c++ zlib-devel openssl-devel expat-devel ffmpeg ffmpeg-devel qt5-qtbase-devel
wget http://www.makemkv.com/download/makemkv-bin-1.10.6.tar.gz
wget http://www.makemkv.com/download/makemkv-oss-1.10.6.tar.gz
tar -xzf ./makemkv-oss-1.10.6.tar.gz
cd ./makemkv-oss-1.10.6
./configure
make
sudo make install
cd ..
rm -rf ./makemkv-oss-1.10.6
rm ./makemkv-oss-1.10.6.tar.gz
tar -xzf ./makemkv-bin-1.10.6.tar.gz
cd makemkv-bin-1.10.6
make
sudo make install
cd ..
rm -rf makemkv-bin-1.10.6
rm ./makemkv-bin-1.10.6.tar.gz
This is my debug log (as a result of trying to read the BD "Safe" with Jason Statham):
Debug log started at Sat Jun 24 02:20:54 2017 , written by MakeMKV v1.10.6 linux(x64-release)
001005:0000 MakeMKV v1.10.6 linux(x64-release) started
001004:0000 Debug logging enabled, log will be saved as /home/brendan/MakeMKV_log.txt
DEBUG: Code 2147483648 at Sk_f7I>A(`&dD>qx:121265315
DAFD=PAAAADAAAAEABDQkEEwEBAQ==
001003:0020 DEBUG: Code 0 at W~ZA$vK;|{n10c S[O:213130789
003341:0000 Highest AACS version is v37 , MKB saved as /home/brendan/.MakeMKV/MKB_v37_SAFE.tgz
001003:0020 DEBUG: Code 0 at ,M1{q3WO9x`>\1E5:29396046
001003:0020 DEBUG: Code 0 at ,M1{q3WO9x`>\1E5:213134009
Please let me know if I can provide any further information, thanks.
Disclaimer: All of my discs are my own and have been purchased through Australian retail stores.
hernebay
#6 Post by hernebay » Wed Jun 28, 2017 10:41 pm
Problem is with the Fedora 26 version of MakeMKV. Workaround is to (force..) install the Fedora 25 version, which works correctly.
trekkie690
#7 Post by trekkie690 » Fri Jul 07, 2017 2:42 pm
So on FC26 (beta) as well. Same problem. The question how do you force the OpenSSL libraries to downgrade when they are at the lowest level. You have to force FC25 vesion but you get a conflict install since removing openssl also removes DNF which is protected and not authorized to be removed?
hernebay
#8 Post by hernebay » Fri Jul 07, 2017 8:35 pm
No need to replace OpenSSL. Keep the F26 version. Only need to replace the F26 version of MakeMKV (and mmdtsdec..) with the F25 version. Simplest to just d/l the RPMs from the F25 repository, and then use # rpm -Uvh <rpmname> --force --nodeps
trekkie690
#9 Post by trekkie690 » Sun Jul 09, 2017 8:28 pm
So i compiled from source, which then the question is anyone know what library is needed for it to compile correctly (yeah im being lazy)?
brendan
#10 Post by brendan » Mon Jul 10, 2017 8:23 am
Yes, as mentioned above, I am compiling from source too, so using F25 RPM's is not an option.
If the F25 RPM's are working, the question is: what is different in F26 and how can we (either through Fedora or through MakeMKV) resolve the root cause of the issue?
AkiraNorthstar
#11 Post by AkiraNorthstar » Mon Jul 17, 2017 6:42 am
Please rebuild makemkv with using the source rpm under fedora 26, but change the BuildRequires: openssl-devel to compat-openssl10-devel in makemkv.spec.
(https://negativo17.org/category/makemkv/ or https://negativo17.org/repos/multimedia ... -26/SRPMS/)
This will will fix the 00FC error after rebuild.
Regrads,
AkiraNorthstar
Asus BW-16D1HT FW: 3.10 2119-01-04 10:14 | HL-DT-ST BD-RE BH16NS40 FW: 1.03 2114-03-26 11:15
AkiraNorthstar
#12 Post by AkiraNorthstar » Mon Jul 17, 2017 6:48 am
Additional infos about openssl under fedora :
https://pagure.io/release-notes/c/d92bb ... branch=f26
AkiraNorthstar
#13 Post by AkiraNorthstar » Mon Jul 17, 2017 12:50 pm
Simone (negativio17.org) updated makemkv today to 1.10.6-2 (Use OpenSSL 1.0.x also on Fedora 26).
This issue can be closed now, happy ripping ;-)
AkiraNorthstar
nickieh
#14 Post by nickieh » Thu Aug 31, 2017 8:28 pm
AkiraNorthstar wrote:Simone (negativio17.org) updated makemkv today to 1.10.6-2 (Use OpenSSL 1.0.x also on Fedora 26).
AkiraNorthstar
Have the compat-openssl10 package on my box, reinstalled the Negativio17 repo then removed/reinstalled makemkv based on the above. Same problem. ????
$ dnf config-manager --add-repo=https://negativo17.org/repos/fedora-multimedia.repo
$ dnf list installed|grep openssl10
compat-openssl10.x86_64 1:1.0.2j-6.fc26 @@commandline
$ dnf list installed | grep makemkv
makemkv.x86_64 1.10.6-2.fc26 @fedora-multimedia
Suggestions?
nickieh
#15 Post by nickieh » Fri Sep 15, 2017 6:57 pm
Pulled in the negativo17 source repo for 1.10.7 & rebuilt using the compat-openssl10 package, successfully ripping now. Thanks all.
