Disney World Of Wonder Blu-ray
Romansh
#1 Post by Romansh » Wed Sep 28, 2011 2:05 pm
UPC 7 86936 80702 8
AACS v18
Debug log:
Debug log started at Wed Sep 28 13:24:19 2011 , written by MakeMKV v1.6.15 darwin(x86-release)
001005:0000 MakeMKV v1.6.15 darwin(x86-release) started
001004:0000 Debug logging enabled, log will be saved as /Users/romansh/MakeMKV_log.txt
002014:0000 Optical drive "DVD+R-DL OPTIARC DVD RW AD-5680H 3AHB" opened in DASPI v1.3 mode.
002014:0000 Optical drive "BD-RE HL-DT-ST BD-RE  BH10LS30 1.01" opened in DASPI v1.3 mode.
005072:0000 Backing up disc into folder "/Users/romansh/Movies/DISNEY_WOW"
DAFD=PAAAADAAAAEABDQUEAQEBAQIBDQAAAAAgAAAAAAAAAAA=
DCE=3WJ/3q9kgoyxFaOfDmlX2VLd3NksZQTkAbPXoWzLcIjJRfrE+Zx8Fm4vGDZ9uY2rXgvWS9eaX5G7K6OfWKijlrEU1CTgJCIkFRF/hMxevvaqxOY0EQ9W+txv20U2BvYpImWaGvJzJzhLBMZxtZQ6cX+KJeiUqwbS9Q==
001003:0020 DEBUG: Code 2 at +1,c!YN**2r"i;s&+Bf+=I:29393677
001003:0020 DEBUG: Code 0 at r]|XQc7$4wutnw?(Sme-:121268949
001003:0020 DEBUG: Code 0 at r]|XQc7$4wutnw?(Sme-:121266994
001003:0020 DEBUG: Code 0 at r]|XQc7$4wutnw?(Sme-:213142542
005069:0080 Backup failed
005080:0204 Backup failed.
Re: Disney World Of Wonder Blu-ray
#2 Post by mike admin » Fri Oct 07, 2011 6:37 pm
Does it have a "DCOPY" directory on disc? If yes, then start backup as usual, quickly navigate into target backup folder and creaate a "DCOPY" directory there. Backup should succeed.
This will be fixed in the next version.
Romansh
#3 Post by Romansh » Sat Dec 03, 2011 2:51 pm
Sorry for the late reply. IIRC, it does have a DCOPY folder.
When I get around to testing the new version on this particular disc, I'll let you know how it goes.
Romansh
#4 Post by Romansh » Mon Feb 13, 2012 2:25 pm
FWIW, MakeMKV 1.7.2 was able to successfully backup this disk.
Romansh
#5 Post by Romansh » Sun Feb 19, 2012 2:38 am
BTW, no DCOPY folder - but a ROM_DATA_WOW_ENCODER_TEST folder.
egorss78
#6 Post by egorss78 » Sat Jul 01, 2017 1:54 am
Sorry to reply to an old thread, but looks like I can not rip this BR disk. Using the latest version of makemkv. Log is attached. Have tried different BR drives and cleaned the disk. Plays fine on BR player. Ideas?
yorgo
#7 Post by yorgo » Sat Jul 01, 2017 12:37 pm
No log attached, please post error messages directly into your reply.
egorss78
#8 Post by egorss78 » Sun Jul 02, 2017 2:02 pm
Sorry about that.
MakeMKV v1.10.6 win(x64-release) started
Title #00021.mpls has length of 177 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00287.mpls has length of 492 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00299.mpls has length of 341 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00301.mpls has length of 245 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00302.mpls has length of 219 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00250.mpls has length of 504 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00250.mpls(2) has length of 525 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00250.mpls(4) has length of 642 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00250.mpls(6) has length of 457 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00250.mpls(8) has length of 465 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00250.mpls(10) has length of 426 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00250.mpls(12) has length of 492 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00020.mpls has length of 177 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00304.mpls(4) has length of 136 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00309.mpls has length of 295 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00324.mpls has length of 159 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00324.mpls(12) has length of 162 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00324.mpls(15) has length of 419 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00325.mpls has length of 159 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00331.mpls has length of 219 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00295.mpls(1) has length of 986 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00427.mpls has length of 100 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00427.mpls(1) has length of 100 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00427.mpls(2) has length of 100 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00427.mpls(3) has length of 100 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00430.mpls has length of 120 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00430.mpls(1) has length of 120 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00430.mpls(2) has length of 120 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00430.mpls(3) has length of 120 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00430.mpls(4) has length of 120 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00430.mpls(5) has length of 120 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00431.mpls has length of 140 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00431.mpls(1) has length of 140 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00431.mpls(2) has length of 140 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00431.mpls(3) has length of 140 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00431.mpls(4) has length of 140 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00431.mpls(5) has length of 140 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00440.mpls has length of 28 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00444.mpls has length of 74 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00444.mpls(1) has length of 74 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00444.mpls(2) has length of 74 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00444.mpls(3) has length of 74 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00445.mpls has length of 87 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00445.mpls(1) has length of 87 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00445.mpls(2) has length of 87 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00445.mpls(3) has length of 87 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00445.mpls(4) has length of 87 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00446.mpls has length of 103 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00446.mpls(1) has length of 103 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00446.mpls(2) has length of 103 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00446.mpls(3) has length of 103 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00446.mpls(4) has length of 103 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00446.mpls(5) has length of 103 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00453.mpls has length of 183 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00453.mpls(1) has length of 183 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00453.mpls(2) has length of 183 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00453.mpls(3) has length of 183 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00453.mpls(4) has length of 183 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00453.mpls(5) has length of 183 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00453.mpls(6) has length of 183 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00453.mpls(7) has length of 183 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00453.mpls(8) has length of 183 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00455.mpls has length of 461 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00455.mpls(1) has length of 461 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00455.mpls(2) has length of 461 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00455.mpls(3) has length of 461 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00455.mpls(4) has length of 461 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00455.mpls(5) has length of 461 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00455.mpls(6) has length of 461 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00455.mpls(7) has length of 461 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00455.mpls(8) has length of 461 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00455.mpls(9) has length of 461 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00455.mpls(10) has length of 461 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00455.mpls(11) has length of 461 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00455.mpls(12) has length of 461 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00455.mpls(13) has length of 461 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00455.mpls(14) has length of 461 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00455.mpls(15) has length of 461 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00455.mpls(16) has length of 461 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00455.mpls(17) has length of 461 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00455.mpls(18) has length of 461 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00455.mpls(19) has length of 461 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00455.mpls(20) has length of 461 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00455.mpls(21) has length of 461 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00455.mpls(22) has length of 461 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00455.mpls(23) has length of 461 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00455.mpls(24) has length of 461 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00456.mpls has length of 559 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00456.mpls(1) has length of 559 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00456.mpls(2) has length of 559 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00456.mpls(3) has length of 559 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00456.mpls(4) has length of 559 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00456.mpls(5) has length of 559 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00456.mpls(6) has length of 559 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00456.mpls(7) has length of 559 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00456.mpls(8) has length of 559 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00456.mpls(9) has length of 559 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00456.mpls(10) has length of 559 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00456.mpls(11) has length of 559 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00456.mpls(12) has length of 559 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00456.mpls(13) has length of 559 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00456.mpls(14) has length of 559 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00456.mpls(15) has length of 559 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00456.mpls(16) has length of 559 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00456.mpls(17) has length of 559 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00456.mpls(18) has length of 559 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00456.mpls(19) has length of 559 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00456.mpls(20) has length of 559 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00456.mpls(21) has length of 559 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00456.mpls(22) has length of 559 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00456.mpls(23) has length of 559 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00456.mpls(24) has length of 559 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00456.mpls(25) has length of 559 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00456.mpls(26) has length of 559 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00456.mpls(27) has length of 559 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00456.mpls(28) has length of 559 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00456.mpls(29) has length of 559 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00457.mpls has length of 645 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00457.mpls(1) has length of 645 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00457.mpls(2) has length of 645 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00457.mpls(3) has length of 645 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00457.mpls(4) has length of 645 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00457.mpls(5) has length of 645 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00457.mpls(6) has length of 645 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00457.mpls(7) has length of 645 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00457.mpls(8) has length of 645 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00457.mpls(9) has length of 645 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00457.mpls(10) has length of 645 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00457.mpls(11) has length of 645 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00457.mpls(12) has length of 645 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00457.mpls(13) has length of 645 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00457.mpls(14) has length of 645 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00457.mpls(15) has length of 645 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00457.mpls(16) has length of 645 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00457.mpls(17) has length of 645 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00457.mpls(18) has length of 645 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00457.mpls(19) has length of 645 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00457.mpls(20) has length of 645 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00457.mpls(21) has length of 645 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00457.mpls(22) has length of 645 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00457.mpls(23) has length of 645 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00457.mpls(24) has length of 645 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00457.mpls(25) has length of 645 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00457.mpls(26) has length of 645 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00457.mpls(27) has length of 645 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00457.mpls(28) has length of 645 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00457.mpls(29) has length of 645 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00457.mpls(30) has length of 645 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00457.mpls(31) has length of 645 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00457.mpls(32) has length of 645 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00457.mpls(33) has length of 645 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00461.mpls has length of 224 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00461.mpls(1) has length of 224 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00461.mpls(2) has length of 224 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00461.mpls(3) has length of 224 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00461.mpls(4) has length of 224 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00461.mpls(5) has length of 224 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00461.mpls(6) has length of 224 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00461.mpls(7) has length of 224 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00461.mpls(8) has length of 224 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00461.mpls(9) has length of 224 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00461.mpls(10) has length of 224 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00461.mpls(11) has length of 224 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00461.mpls(12) has length of 224 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00461.mpls(13) has length of 224 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00461.mpls(14) has length of 224 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00461.mpls(15) has length of 224 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00461.mpls(16) has length of 224 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00461.mpls(17) has length of 224 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00461.mpls(18) has length of 224 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00461.mpls(19) has length of 224 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00461.mpls(20) has length of 224 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00461.mpls(21) has length of 224 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00461.mpls(22) has length of 224 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00461.mpls(23) has length of 224 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00461.mpls(24) has length of 224 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00461.mpls(25) has length of 224 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00461.mpls(26) has length of 224 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00461.mpls(27) has length of 224 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00461.mpls(28) has length of 224 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00461.mpls(29) has length of 224 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00461.mpls(30) has length of 224 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00461.mpls(31) has length of 224 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00461.mpls(32) has length of 224 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00461.mpls(33) has length of 224 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00461.mpls(34) has length of 224 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00461.mpls(35) has length of 224 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00461.mpls(36) has length of 224 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00461.mpls(37) has length of 224 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00461.mpls(38) has length of 224 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00461.mpls(39) has length of 224 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00461.mpls(40) has length of 224 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00461.mpls(41) has length of 224 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00461.mpls(42) has length of 224 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00461.mpls(43) has length of 224 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00478.mpls has length of 49 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00358.mpls has length of 4 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00391.mpls has length of 6 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00357.mpls has length of 10 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00251.mpls has length of 100 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00252.mpls has length of 63 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00273.mpls has length of 106 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00274.mpls has length of 51 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00275.mpls has length of 70 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00538.mpls has length of 96 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00005.m2ts has length of 34 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00013.m2ts has length of 0 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00014.m2ts has length of 0 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00067.m2ts has length of 96 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00416.m2ts has length of 0 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00420.m2ts has length of 58 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00423.m2ts has length of 73 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00425.m2ts has length of 112 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00427.m2ts has length of 69 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00428.m2ts has length of 90 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00429.m2ts has length of 65 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00430.m2ts has length of 85 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00431.m2ts has length of 45 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00432.m2ts has length of 65 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00433.m2ts has length of 128 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00434.m2ts has length of 66 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00435.m2ts has length of 73 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00436.m2ts has length of 93 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00437.m2ts has length of 68 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00438.m2ts has length of 61 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00439.m2ts has length of 81 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00440.m2ts has length of 104 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00441.m2ts has length of 102 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00442.m2ts has length of 46 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00443.m2ts has length of 65 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00444.m2ts has length of 95 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00445.m2ts has length of 53 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00446.m2ts has length of 42 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00447.m2ts has length of 53 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00448.m2ts has length of 42 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00449.m2ts has length of 86 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00450.m2ts has length of 43 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00451.m2ts has length of 35 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00452.m2ts has length of 74 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00454.m2ts has length of 177 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00456.m2ts has length of 0 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00457.m2ts has length of 492 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00458.m2ts has length of 76 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00459.m2ts has length of 112 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00460.m2ts has length of 42 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00461.m2ts has length of 74 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00462.m2ts has length of 100 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00463.m2ts has length of 34 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00464.m2ts has length of 53 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00465.m2ts has length of 26 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00466.m2ts has length of 52 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00467.m2ts has length of 29 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00468.m2ts has length of 341 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00469.m2ts has length of 295 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00470.m2ts has length of 245 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00471.m2ts has length of 219 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00472.m2ts has length of 136 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00473.m2ts has length of 151 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00474.m2ts has length of 64 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00475.m2ts has length of 20 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00476.m2ts has length of 59 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00477.m2ts has length of 10 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00478.m2ts has length of 86 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00479.m2ts has length of 98 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00480.m2ts has length of 387 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00481.m2ts has length of 168 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00482.m2ts has length of 107 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00484.m2ts has length of 67 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00486.m2ts has length of 137 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00487.m2ts has length of 193 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00488.m2ts has length of 107 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00489.m2ts has length of 136 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00490.m2ts has length of 95 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00496.m2ts has length of 78 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00500.m2ts has length of 77 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00501.m2ts has length of 104 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00502.m2ts has length of 108 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00513.m2ts has length of 321 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00514.m2ts has length of 138 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00515.m2ts has length of 114 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00517.m2ts has length of 164 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00518.m2ts has length of 213 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00526.m2ts has length of 87 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00527.m2ts has length of 85 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00528.m2ts has length of 212 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00532.m2ts has length of 114 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00546.m2ts has length of 146 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00549.m2ts has length of 4 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00550.m2ts has length of 4 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00573.m2ts has length of 30 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00577.m2ts has length of 100 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00578.m2ts has length of 120 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00579.m2ts has length of 140 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00580.m2ts has length of 20 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00581.m2ts has length of 12 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00582.m2ts has length of 37 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00583.m2ts has length of 43 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00584.m2ts has length of 55 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00585.m2ts has length of 28 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00586.m2ts has length of 74 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00587.m2ts has length of 87 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00588.m2ts has length of 103 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00589.m2ts has length of 183 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00590.m2ts has length of 14 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00592.m2ts has length of 15 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00593.m2ts has length of 15 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00594.m2ts has length of 14 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00595.m2ts has length of 461 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00596.m2ts has length of 559 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00597.m2ts has length of 645 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00598.m2ts has length of 224 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00600.m2ts has length of 44 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00601.m2ts has length of 35 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00602.m2ts has length of 84 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00603.m2ts has length of 91 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00604.m2ts has length of 93 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00605.m2ts has length of 115 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00606.m2ts has length of 67 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00607.m2ts has length of 51 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00608.m2ts has length of 40 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00609.m2ts has length of 78 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00610.m2ts has length of 85 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00611.m2ts has length of 14 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00612.m2ts has length of 15 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00613.m2ts has length of 23 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00614.m2ts has length of 10 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00615.m2ts has length of 56 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00616.m2ts has length of 56 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00617.m2ts has length of 56 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00618.m2ts has length of 60 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00619.m2ts has length of 212 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00620.m2ts has length of 183 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00621.m2ts has length of 183 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00622.m2ts has length of 183 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00624.m2ts has length of 30 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00625.m2ts has length of 5 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00629.m2ts has length of 177 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00630.m2ts has length of 2 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00631.m2ts has length of 2 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00632.m2ts has length of 2 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00633.m2ts has length of 2 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00634.m2ts has length of 2 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00635.m2ts has length of 2 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00636.m2ts has length of 2 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00637.m2ts has length of 2 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00638.m2ts has length of 2 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00639.m2ts has length of 2 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00640.m2ts has length of 2 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00641.m2ts has length of 2 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00642.m2ts has length of 2 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00643.m2ts has length of 2 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00644.m2ts has length of 2 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00645.m2ts has length of 2 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00646.m2ts has length of 2 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00647.m2ts has length of 2 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00648.m2ts has length of 2 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00649.m2ts has length of 2 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00650.m2ts has length of 2 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00651.m2ts has length of 2 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00653.m2ts has length of 2 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00654.m2ts has length of 2 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00655.m2ts has length of 2 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00656.m2ts has length of 2 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00659.m2ts has length of 47 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00660.m2ts has length of 58 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00661.m2ts has length of 44 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00662.m2ts has length of 29 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00663.m2ts has length of 44 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00664.m2ts has length of 39 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00665.m2ts has length of 31 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00666.m2ts has length of 25 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00667.m2ts has length of 18 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00668.m2ts has length of 20 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00669.m2ts has length of 37 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00670.m2ts has length of 2 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00671.m2ts has length of 39 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00672.m2ts has length of 18 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00673.m2ts has length of 18 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00674.m2ts has length of 17 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00675.m2ts has length of 15 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00676.m2ts has length of 32 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00677.m2ts has length of 75 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00678.m2ts has length of 53 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00679.m2ts has length of 27 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00680.m2ts has length of 12 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00681.m2ts has length of 12 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00682.m2ts has length of 12 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00683.m2ts has length of 1 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
#9 Post by Woodstock » Sun Jul 02, 2017 3:23 pm
Shorten your minimum time - everything on that disk is less than an hour long, so nothing rippable is found.
