Have a TV Episode DVD which shows as one file in MakeMKV.
tonyaldr
Post by tonyaldr » Fri Jun 30, 2017 2:55 am
Hi everyone. I have a TV Episode DVD that shows all 20 episodes as a single title with 20 chapters and MakeMKV wants to create a single MKV file. I've read about being able to open it in "manual" mode but can't find how to do that. Has anyone done this? Appreciate some advice. Thx!
Re: Have a TV Episode DVD which shows as one file in MakeMKV
Post by Woodstock » Fri Jun 30, 2017 12:19 pm
/manualdvd/
That's the manual mode you've heard about, but... There are other ways to break up the file AFTER MakeMKV writes it.
If you want to stick with MKV files after the rip, mkvtoolnix has a tool called mkvmerge that can write a files with one or more chapters in them. You can also use handbrake (from handbrake.fr) to compress the video and write either MKV or MP4 files that a wider number of playback devices will handle.
tonyaldr
Post by tonyaldr » Fri Jun 30, 2017 2:16 pm
Thx for the info. Since posting I've learned that the chapters actually do NOT separate the episodes. So I guess I'll need a tool that will allow me to open the single large MKV and place markers/dividers to export the segments as separate files. Sheesh! Talk about complications!
Post by Woodstock » Fri Jun 30, 2017 6:13 pm
Handbrake will work for that, because you can specify what to convert by time. The one thing you have to be careful of is that handbrake whats the time as, "When does it start, and how many seconds should I encode?" Most people think it wants "from what time to what time?"
I'm not sure if mkvmerge will work that way; I haven't tried it.
tonyaldr
Post by tonyaldr » Sat Jul 01, 2017 2:32 pm
Thx! Actually I was able to do it with MKVToolNix GUI! I play the exported large MKV in VLC and step forward by Chapters until I find the beginning of each episode and record the timecodes. A little time consuming but it works perfectly! Thx to everyone for the advice and tips!
angelgraves13
Post by angelgraves13 » Wed Jul 12, 2017 11:57 pm
tonyaldr wrote:Thx! Actually I was able to do it with MKVToolNix GUI! I play the exported large MKV in VLC and step forward by Chapters until I find the beginning of each episode and record the timecodes. A little time consuming but it works perfectly! Thx to everyone for the advice and tips!
You don't need the timecodes. Just split them by the chapter numbers where they begin. Much easier.
Smithcraft
Post by Smithcraft » Fri Aug 11, 2017 11:37 am
It seems he does need to do that:
tonyaldr wrote:Thx for the info. Since posting I've learned that the chapters actually do NOT separate the episodes. So I guess I'll need a tool that will allow me to open the single large MKV and place markers/dividers to export the segments as separate files. Sheesh! Talk about complications!
SC
