Power Rangers 2017
Power Rangers 2017
U.S. Retail
Title information
Name: Saban's Power Rangers
Source file name: 00988.mpls
Duration: 2:03:58
Chapters count: 16
Segment count: 13
Segment map: 505,501,507,502,506,509,511,513,508,504,514,512,510
File name: Saban's_Power_Rangers_t94.mkv
Title information
Duration: 2:03:58
Chapters count: 16
Segment count: 13
Re: Power Rangers 2017
2017-06-27 mpls 0988 doesn't exist on the Redbox version. Anyone have the Redbox BD Power Rangers mpls info?
bill2468 wrote:2017-06-27 mpls 0988 doesn't exist on the Redbox version. Anyone have the Redbox BD Power Rangers mpls info?
I'd love to know also. Redbox edition? Anyone?
MakeMKV selected this stream as the "Primary Feature" on my Redbox disc, but I understand that built in feature is not foolproof.
Title information
Comment: FPL_MainFeature
Source file name: 00886.mpls
Duration: 2:03:58
Chapters count: 16
Segment count: 20
Segment map: 514,505,502,517,510,503,515,509,504,516,508,506,513,520,512,518,511,519,501,507
File name: Saban's_Power_Rangers_t01.mkv
Title information
Duration: 2:03:58
Chapters count: 16
Segment count: 20
Redbox that I have has no 0886 mpls just 0885 and 0887. Any other Redbox Power Rangers mpls?
Oh wait, yes I do have 0886 and the segment map matches also.
Thanks for you help.
Well that segment map does not match the one posted at top so not sure MakeMKV is correct. Will have to watch to be sure.bill2468 wrote:Redbox that I have has no 0886 mpls just 0885 and 0887. Any other Redbox Power Rangers mpls?
Redbox Version
Title information
Duration: 2:03:58
Chapters count: 16
Segment count: 20
File name: Saban's_Power_Rangers_t02.mkv
I had a free rental to burn at Redbox so thought I'd do one for you guys. Enjoy.
Title information
Duration: 2:03:58
Chapters count: 16
Segment count: 20
So 00325 worked? Wasn't sure if you meant you watched and confirmed.
Correction:orion32773 wrote:So 00325 worked? Wasn't sure if you meant you watched and confirmed.
Redbox Version
Title information
Duration: 2:03:58
Chapters count: 16
Segment count: 20
Understood. Thank you!!!hvnphoto wrote:Confirmed. I wouldn't post definitively if it were otherwise. Enjoy.orion32773 wrote:So 00325 worked? Wasn't sure if you meant you watched and confirmed.
Thanks...looks the same on NFX.hvnphoto wrote:Redbox Version
Title information
Source file name: 00325.mpls
Duration: 2:03:58
Chapters count: 16
Segment count: 20
Segment map: 514,505,517,502,510,504,508,515,516,503,509,506,513,519,511,518,520,501,512,507
File name: Saban's_Power_Rangers_t127.mkv
00325 isn't correct for my Redbox copy.
Looks to me like 00886 (the one MakeMKV labels MainFeature) is correct. A spot that was definitely not correct on 325 is fine on 886.
You are correct. I was alerted to a mistake made. I posted the incorrect and definitively wrong playlist. My apologies for posting wrong information.pinpalsapu wrote:00325 isn't correct for my Redbox copy.
The correct is as you stated:
Title information
Duration: 2:03:58
Chapters count: 16
Segment count: 20
Does anyone know if the Amazon US copy is 00509? MakeMKV labeled it as "main feature."
Check 509's segment map to see if it matches what is listed in the first entry of this thread. If it is a match then you have the correct playlist. Do not compare the segment map to that of Redbox's since it is entirely different.xandermoses88 wrote:Does anyone know if the Amazon US copy is 00509? MakeMKV labeled it as "main feature."
