Hacksaw Ridge
caw789
Re: Hacksaw Ridge
When I select the correct title, there is no option for any HD Audio in the pulldown. Am I missing something?
hvnphoto
Re: Hacksaw Ridge
Rental copies do not include the TrueHD 7.1 Atmos if that is what you're looking for.caw789 wrote:When I select the correct title, there is no option for any HD Audio in the pulldown. Am I missing something?
nepenthe
Re: Hacksaw Ridge
theonegod wrote:I am a little confused why you would ask. Not trying to be negative, but at least for me, MakeMKV tells me which one is the feature film in the most current version with this title.czmartinez wrote:Any clue on the Redbox Version?
So what am I missing. I am running the current version, but I have never seen anything that says feature film. I have looked for months now, since it was first posted that it is there.
Re: Hacksaw Ridge
You will only get that notification if the disk has playlist obfuscation AND MakeMKV detects and can use the Java Runtime Environment (JRE) from java.com.
nepenthe
Re: Hacksaw Ridge
I have the JRE installed, it even looks for the JRE before it will even analyze the .isoWoodstock wrote:You will only get that notification if the disk has playlist obfuscation AND MakeMKV detects and can use the Java Runtime Environment (JRE) from java.com.
yorgo
Re: Hacksaw Ridge
Are you using the original BD disc or an .iso file? If the latter, it may not work depending on how the .iso was created.nepenthe wrote:I have the JRE installed, it even looks for the JRE before it will even analyze the .isoWoodstock wrote:You will only get that notification if the disk has playlist obfuscation AND MakeMKV detects and can use the Java Runtime Environment (JRE) from java.com.
Help Keep MakeMKV Going - http://www.makemkv.com/buy/
Latest Beta Key - http://www.makemkv.com/forum2/viewtopic.php?f=5&t=1053
Multiple Playlists? - http://www.makemkv.com/forum2/viewtopic ... 6&start=15
nepenthe
Re: Hacksaw Ridge
I use anydvd and rip the whole BD in an .isoyorgo wrote:Are you using the original BD disc or an .iso file? If the latter, it may not work depending on how the .iso was created.nepenthe wrote:I have the JRE installed, it even looks for the JRE before it will even analyze the .isoWoodstock wrote:You will only get that notification if the disk has playlist obfuscation AND MakeMKV detects and can use the Java Runtime Environment (JRE) from java.com.
Re: Hacksaw Ridge
Mike's original post about this said the Java code on the disk would NOT work on a backup or ISO.
I suspect it is probably something about the physical media that must be present or the code fails. One of the early copy protections on DVD was that a pressed DVD would have a "defective" sector would be manufactured into it that the programs looked for. If that sector was readable, it wasn't the original disk.
Tetra
Re: Hacksaw Ridge
Has anyone else had an issue where Java crashes when trying to open Hacksaw Ridge? I have the "4K UHD + Blu-Ray + Digital HD" copy bought from Target a few weeks ago. I am on Linux, running the latest version of makemkv and have tried both OpenJDK and Java binaries.
jcmkv
Re: Hacksaw Ridge
515, 513, 503, 510, 505, 506, 508, 504, 502, 501, 514, 509, 520, 518, 516, 517, 512, 507sweakley2012 wrote: Tue Feb 21, 2017 10:07 pm Still looking for playlist for redbox Blu-ray version. Anyone solved this one yet?
It is track t269.
jdunn0214@gmail.com
Re: Hacksaw Ridge
yes matches mine as well thank youCIR Engineering wrote: Wed Feb 15, 2017 9:43 pm Also looks like playlists 00001.mpls and 00377.mpls matches on mine.
non
TheMonkeyBob
Re: Hacksaw Ridge
For any Canadians looking for the correct playlist, you can try this one.
Compare the barcode to see if they match. https://www.barcodelookup.com/191329000526
Title information
Source file name: 00777.mpls
Duration: 2:19:19
Chapters count: 16
Segment count: 20
Segment map: 513,510,507,504,506,517,520,512,505,518,516,502,509,508,503,511,501,515,519,514
File name: Hacksaw Ridge_t346.mkv
Title information
Duration: 2:19:19
Chapters count: 16
Segment count: 20
GreenLantern1978
Re: Hacksaw Ridge
Thanks You This worked for me.TheMonkeyBob wrote: Mon Jan 03, 2022 11:20 pm For any Canadians looking for the correct playlist, you can try this one.
Title information
Duration: 2:19:19
Chapters count: 16
Segment count: 20
