Rottatouille: Makes MakeMKV not respond
frank_jarle
#1 Post by frank_jarle » Tue May 25, 2010 7:03 pm
Im trying to convert Rottatouille, but every single time the program just goes into a "Not responding" state.
OS: Windows 7, 64bit
MakeMKV: 1.5.6
Title: Rottatouille
DVD Region: 2 (Norway)
Is this DVD know for having problems, i have tried using different versions of MakeMKV to no vail :(
Frank
setarip_old
Re: Rottatouille: Makes MakeMKV not respond
#2 Post by setarip_old » Tue May 25, 2010 8:08 pm
Hi!
Sounds like a dirty or physically damaged disc.
Have you successfully used MakeMKV with other DVDs?
frank_jarle
#3 Post by frank_jarle » Tue May 25, 2010 9:10 pm
I dont believe it can be any of these things, because i have two completely new disc of the same movie, same result with both.
Frank
frank_jarle
#4 Post by frank_jarle » Tue May 25, 2010 9:22 pm
And yes i have other movies that convert without problem... :)
setarip_old
#5 Post by setarip_old » Wed May 26, 2010 12:34 am
As a means of determining whether your drive may be problematic, see if you obtain the same results by trying to rip the same "Ratatouille" DVD(s) with a different (current) ripping program, such as the freeware version of DVD95Copy or DVDFab ("DVDFabHD" is the freeware version)...
drsuchit
#6 Post by drsuchit » Wed May 26, 2010 5:48 am
setarip_old wrote:As a means of determining whether your drive may be problematic, see if you obtain the same results by trying to rip the same "Ratatouille" DVD(s) with a different (current) ripping program, such as the freeware version of DVD95Copy or DVDFab ("DVDFabHD" is the freeware version)...
I suspect a mastering error may be to blame....
Is the disc a dual layer recordable burn of a previously ripped image of the same disc?
Do you have any freeware realtime copy protection strippers/emulators running in the background?
