John Wick Chapter 2
tarmac
Re: John Wick Chapter 2
Post by tarmac »
Has anyone had any luck with the Netflx version? 440 is not on the netflix version
postaldude057
Post by postaldude057 »
blabbo wrote:On the Netflix disc, there is no 440.mpls or 487.mpls. There's a 607.mpls, but the playlist is different:
502,505,512,504,516,509,501,514,510,513,507,519,520,508,515,511,506,518,503,517
None of the playlists on the Netflix disc have 508 as the second segment.
I can confirm, I checked as well. There was no 502,508,......
twomanytoyz
Post by twomanytoyz »
Anyone with the netflix version?
unab0mb
Post by unab0mb »
Correct title for Netflix version:
Title information
Name: John Wick Chapter 2 (English)
Source file name: 00934.mpls
Duration: 2:02:22
Chapters count: 16
Segment count: 20
Segment map: 502,505,512,504,516,515,513,506,509,510,514,518,511,501,520,503,519,508,507,517
File name: John_Wick_Chapter_2_t369.mkv
SteveInNC
Post by SteveInNC »
Zenophobe wrote:440.mpls on Retail I get the following:
Title information
Source file name: 00440.mpls
Duration: 2:02:22
Chapters count: 16
Segment count: 13
Segment map: 502,508,501,514,506,503,505,515,513,512,504,507,511
File name: John_Wick_Chapter_2_t142.mkv
This is a 7.1 Dolby Atmos disk
Is this the correct retail choice?
BroadStreetPhila
Post by BroadStreetPhila »
unab0mb wrote:Correct title for Netflix version:
Title information
Duration: 2:02:22
Chapters count: 16
Segment count: 20
Out of curiosity, how'd you come up with this?
Using the PowerDVD/ProcessMonitor method (does that still work reliably?), I got the following with my Netflix US version:
Title information
Source file name: 00121.mpls
Duration: 2:02:22
Chapters count: 16
Segment count: 20
Segment map: 502,505,516,513,504,512,515,506,514,510,509,518,501,520,511,503,508,507,519,517
File name: John_Wick_Chapter_2_t46.mkv
Last edited by BroadStreetPhila on Wed Jun 14, 2017 12:05 am, edited 2 times in total.
pleiosaur
Post by pleiosaur »
pleiosaur wrote:Redbox segment mapping looks like it should be:
Seems to map to 440.mpls on mine.
For anyone having trouble with this, VLC doesn't process the 7.1 channel correctly so you can either uncheck the 7.1 channel in the audio dropdown section and just keep the stereos/5.1 channels, or just get all of it and keep the tracks.
Good luck guys.
mjensen939
Post by mjensen939 »
Title information
Duration: 2:02:22
Chapters count: 16
Segment count: 20
I have viewed and can confirm this is correct!
tron21net
Post by tron21net »
Confirming that this is correct for retail disc, from Amazon in my case:
hvnphoto wrote:Source file name: 00440.mpls
Played back just fine using MPC-HC v1.7.8. Did use audio track TrueHD 48000Hz 8ch 9216kbps [A: Surround 7.1 [eng] (truehd, 48000 Hz, 7.1, s24)].
Lovely Rita
Post by Lovely Rita »
Java support will need to be tweaked. As you can see it begins to run but does not slice and dice its way through all of the fakes to display the correct title (FPL_MainFeature).
I'll forward the necessary files to Mike.
Registered User :wink:
Buy MakeMKV
thedigitalhobo
Post by thedigitalhobo »
PowerDVD/ProcessMonitor method showing 121 for me as well. But I haven't seen the movie yet, so I can't compare. Can anyone else confirm / validate?
Title information
Duration: 2:02:22
Chapters count: 16
Segment count: 20
gamecaptor
Post by gamecaptor »
Redbox Version
Total size: 24372416 sectors (47602 MBytes)
Video Blu-ray label: JOHN_WICK_CHAPTER_2
Media is AACS protected!
Drive supports bus encryption!
Disc wants bus encryption!
AACS MKB version 62
Removed AACS copy protection!
Note: automatic detection of region code not possible with this disc.
Blu-ray Java signatures fixed!
BD-Live deactivated!
Sony structural BD-J protection removed!
Java BD protection good playlists: 440
StivKlin
Post by StivKlin »
Is anyone getting this problem?
This disc uses newer version of AACS protection. Please let us know about it by visiting /a/?4uLi4uJg2UXCtv...
Rolyatja
Post by Rolyatja »
PowerDVD/Process Monitor showing G:\BDMV\PLAYLIST\00378.mpls
Canada, rental disk.
Title information
Source file name: 00378.mpls
Duration: 2:02:22
Chapters count: 16
Segment count: 13
Segment map: 514,502,501,503,511,504,505,515,508,513,506,507,512
File name: John_Wick_Chapter_2_t136.mkv
Let me know if this mpls/segment map works for others!
BroadStreetPhila
Title information
Duration: 2:02:22
Chapters count: 16
Segment count: 20
I can confirm as well for US Netflix.
