Hi
I'm using the Heyarje PPA on Ubuntu 17.04 and it's not updating when I do a apt-get update upgrade
The update looks odd as it lists a load of errors for artful and artful/main
When I try and force update makemkv-bin it saus 1.10.5-1-yakkety is the newest version although I can see on the website that 1.10.6 is available
https://launchpad.net/~heyarje/+archive ... kemkv-beta
Any advise on how I can fix this please?
Heyarje PPA Not Updating
Re: Heyarje PPA Not Updating
You would have to ask the owner of that site - it's not an official MakeMKV download.
OK thanks will do, was just check to see if anyone else on here had encountered the same issue.
I think it's more to do with my Ubuntu installation that the site.
If I find a fix will post it on here too though
The Ubuntu upgrade has removed the ppa from my sources list.
Added
deb http://ppa.launchpad.net/heyarje/makemkv-beta/ubuntu zesty main
to
/etc/apt/sources.list
then did an apt-get update and apt-get upgrade and the new version was installed
Added
to
