[Version 1.10.6] Does not open BD 4K
dom61
#1 Post by dom61 » Mon Jun 12, 2017 11:06 am
good morning.
I can not open the Bluray Disk 4K for the movie "Inferno".
I also decrypted the disk on HDD, and just select the "index.bdmw" file, Make MKV returns the message "I can not open the disk".
Is this problem solved?
Thank you
Ugoos AM6B Plus | Remote control G20S PRO Plus | Splitter HDMI HDFury AVR-KEY | Display LG 65B6V | Cables HDMI KabelDirekt Pro series | Audio processor Yamaha RX-V775 | Rotel RMB-1075 | Storage Qnap Ts-431K +TL-D800C |
My PC Ryzen 7950X
yorgo
Re: [Version 1.10.6] Does not open BD 4K
#2 Post by yorgo » Mon Jun 12, 2017 11:12 am
4K Blu-Ray discs use a copy-protection scheme called AACS 2.0 encryption which has not yet been defeated. Until it is, whether by MakeMKV or another party, you will not be able to back up your 4K discs.
dom61
#3 Post by dom61 » Mon Jun 12, 2017 1:21 pm
Thank you for the reply.
We hope MakeMKV can be upgraded with the new decryption keys. :roll:
My PC Ryzen 7950X
yorgo
#4 Post by yorgo » Tue Jun 13, 2017 8:06 pm
Sure, would be great, but defeating AACS 2.0 is not going to be like defeating standard Blu-Ray encryption, so I wouldn't hold my breath...
You may want to read this in the meantime: http://www.makemkv.com/forum2/viewtopic.php?f=1&t=16115
