good morning.
I can not open the Bluray Disk 4K for the movie "Inferno".
I also decrypted the disk on HDD, and just select the "index.bdmw" file, Make MKV returns the message "I can not open the disk".
Is this problem solved?
Thank you
[Version 1.10.6] Does not open BD 4K
Zidoo Z9X | HiMedia Q5 Pro and Q10 Pro | ZDMC 20.1 | Remote WeChip | Splitter HDMI HDFury AVR-KEY | Display LG 65B6V | Audio processor Yamaha RX-V775 | Rotel RMB-1075 | Storage Qnap Ts-431K +TL-D800C
My PC Ryzen 7950X
My PC Ryzen 7950X
Re: [Version 1.10.6] Does not open BD 4K
4K Blu-Ray discs use a copy-protection scheme called AACS 2.0 encryption which has not yet been defeated. Until it is, whether by MakeMKV or another party, you will not be able to back up your 4K discs.
Help Keep MakeMKV Going - http://www.makemkv.com/buy/
Latest Beta Key - http://www.makemkv.com/forum2/viewtopic.php?f=5&t=1053
Multiple Playlists? - http://www.makemkv.com/forum2/viewtopic ... 6&start=15
Thank you for the reply.
We hope MakeMKV can be upgraded with the new decryption keys.
My PC Ryzen 7950X
My PC Ryzen 7950X
Sure, would be great, but defeating AACS 2.0 is not going to be like defeating standard Blu-Ray encryption, so I wouldn't hold my breath...
You may want to read this in the meantime: http://www.makemkv.com/forum2/viewtopic.php?f=1&t=16115
