The "No Disc" issue
jmc0208
Re: The "No Disc" issue
Post by jmc0208 »
Here's the debug log
MakeMKV v1.10.6 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\Jonathan/MakeMKV_log.txt
DEBUG: Code 117506160 at sbr~pqm7/5F,%i"y/(:213131686
DEBUG: Code 117506160 at sbr~pqm7/5F,%i"y/(:29393930
Error 'Internal error - Operation was cancelled (112)' occurred while reading 'BD-ROM HL-DT-ST BDDVDRW CP40NG10 1.00' at offset '657408'
Error 'Internal error - Operation was cancelled (112)' occurred while reading 'BD-ROM HL-DT-ST BDDVDRW CP40NG10 1.00' at offset '659456'
LIBMKV_TRACE: UDF mount: disc not properly formatted or damaged disc (rootdirs failing)
Error 'Internal error - Operation was cancelled (112)' occurred while reading 'BD-ROM HL-DT-ST BDDVDRW CP40NG10 1.00' at offset '32768'
DEBUG: Code 0 at )~tv9zQgS7<*'<,z_U`:213129777
That is an indication that something in the operating system is blocking access to the disk, if the drive disappears in Explorer or Finder. Can't say I've seen that before, but I use Windows 7.
