When opening the disc for this BLURAY feature (A CURE FOR WELLNESS), I get this error message, "BD+ code processed but no FUTs were obtained, errors may follow"
I hit OK and continued making a MKV file, but the MKV file has glitches all the way through the feature when viewing.
Thoughts?
Best,
Rachel
A CURE FOR WELLNESS ERROR - BD+ code processed but no FUTs
rfowl_editor
Re: A CURE FOR WELLNESS ERROR - BD+ code processed but no FU
When you got the error, you should have also had the path to a file to send to svq@makemkv.com. Did you send it?
rfowl_editor
So.....I didn't send the path to svq@makemkv.com - but magically the disc just started working without giving the error message. What is the cause of this?
Most likely the upload made by the OTHER person who asked about this a couple of days ago was used by Mike to generate the SVQ file to fix it...
/svq/ for more information.
