A List of Discs that Fail to Rip
Krobar
Re: A List of Discs that Fail to Rip
Post by Krobar »
1.5.6 is a big improvement. It seems to have fixed all itles that caused MakeMKV to crash and a few others. None of the discs that still dont rip crash MakeMKV anymore.
Krobar
Post by Krobar »
A few more added although compatability is overall very good with current version.
Krobar
Post by Krobar »
More Added.
Please could you move this to the DVD Error Reports forum (Forum did not exist when I started this thread).
Mr_Orange
Post by Mr_Orange »
Is Die Hard 4.0 region 2 still a problem disc?
I am unable to rip it using an LG DVD drive.
TIA.
Since the topic you're replying to is almost 9 years old, and covers version 1.5.6 (we're on 1.14.4 now), I'd say this topic is well beyond "obsolete".
If you're experiencing rip errors, please read here first!
Mr_Orange
Post by Mr_Orange »
Woodstock wrote: Sun Jul 14, 2019 12:43 pm Since the topic you're replying to is almost 9 years old, and covers version 1.5.6 (we're on 1.14.4 now), I'd say this topic is well beyond "obsolete".
I came to the thread via Google and am new to the forum so did not immediately notice how old the thread was.
Be that as it may, I am using version 1.14.4 and cannot successfully rip Die Hard 4.0, region 2 DVD.
I'll have a read of the thread you linked me to, thank you.
Grauhaar
Post by Grauhaar »
You should provide an Debug Log: https://www.makemkv.com/faq/item/8
Good Luck :)
Mr_Orange
Post by Mr_Orange »
Grauhaar wrote: Mon Jul 15, 2019 11:04 am You should provide an Debug Log: https://www.makemkv.com/faq/item/8
Here is the output from the Debug Log:
Debug log started at Mon Jul 15 13:01:07 2019 , written by MakeMKV v1.14.4 win(x64-release)
001005:0000 MakeMKV v1.14.4 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\piers.james/MakeMKV_log.txt
No  SDF v05c: HL-DT-ST_DVDRAM_GH24NS95_RN00_201209201126_KTTC9RH0636
SDF id v05c: HL-DT-ST_DVDRAM_GH24NS95_RN00_201209201126_KTTC9RH0636
No auto SDF v05c: HL-DT-ST_DVDRAM_GH24NS95_RN00_201209201126_KTTC9RH0636
DEBUG: Code 0 at }yJ2^mTS!\xYjfa7w:29395540
DEBUG: Code 0 at CG@,2:kgy4{A|JeZI:121261773
DEBUG: Code 0 at CG@,2:kgy4{A|JeZI:29393792
001003:0020 DEBUG: Code 100864261 at Lt[RKo\%gO`]aK^U:213137574
001003:0020 DEBUG: Code 100864261 at e7]KVtM7J@G@6#ej:121262417
001003:0020 DEBUG: Code 100864261 at ueX$([U\RyQWMQ{AgE:29395701
001003:0020 DEBUG: Code 100864261 at ueX$([U\RyQWMQ{AgE:121261934
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/VIDEO_TS/VTS_03_1.VOB' at offset '0'
001003:0020 DEBUG: Code 0 at d'Sj)YmyXNhv|Y:213136953
001003:0020 DEBUG: Code 0 at d'Sj)YmyXNhv|Y:121261819
001003:0020 DEBUG: Code 0 at CG@,2:kgy4{A|JeZI:29394965
003028:0000 Title #1 was added (32 cell(s), 1:48:07)
003025:0000 Title #2 has length of 218 seconds which is less than minimum title length of 600 seconds and was therefore skipped
003025:0000 Title #3 has length of 31 seconds which is less than minimum title length of 600 seconds and was therefore skipped
003025:0000 Title #4 has length of 21 seconds which is less than minimum title length of 600 seconds and was therefore skipped
003025:0000 Title #5 has length of 98 seconds which is less than minimum title length of 600 seconds and was therefore skipped
003025:0000 Title #6 has length of 66 seconds which is less than minimum title length of 600 seconds and was therefore skipped
003025:0000 Title #7 has length of 468 seconds which is less than minimum title length of 600 seconds and was therefore skipped
003025:0000 Title #8 has length of 270 seconds which is less than minimum title length of 600 seconds and was therefore skipped
003025:0000 Title #9 has length of 347 seconds which is less than minimum title length of 600 seconds and was therefore skipped
003014:0000 Title #9 in broken titleset was skipped
001003:0020 DEBUG: Code 233 at 2FeL0Ps/d7nKYA9IwJWokiNo:0
005014:0000 Saving 1 titles into directory E:/incoming/temp/hb
001003:0020 DEBUG: Code 3221225628 at 2)Me.@84\|r*6W&&&97..1e^:29394091
001003:0020 DEBUG: Code 3221225628 at e7]KVtM7J@G@6#ej:121262417
002003:0000 Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '26624'
DEBUG: Code 3221225628 at ueX$([U\RyQWMQ{AgE:121262693
001003:0020 DEBUG: Code 3221225628 at ueX$([U\RyQWMQ{AgE:29394758
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/VIDEO_TS/VTS_01_1.VOB' at offset '26624'
DEBUG: Code 100864261 at ueX$([U\RyQWMQ{AgE:121262693
001003:0020 DEBUG: Code 100864261 at ueX$([U\RyQWMQ{AgE:29394758
001003:0020 DEBUG: Code 0 at kstXQhz>sC3xud$ta/Bp:29395011
001003:0020 DEBUG: Code 0 at 1I^He/VNrKbQou9i\-`:213129915
001003:0020 DEBUG: Code 0 at kstXQhz>sC3xud$ta/Bp:29394459
001003:0020 DEBUG: Code 13 at kstXQhz>sC3xud$ta/Bp:29393286
001003:0020 DEBUG: Code 0 at D8L"~H<8yPg*12}M1MpW{:213136608
001003:0020 DEBUG: Code 0 at \M2)&;{$qvan/C5Z1b9:213131870
AV sync issues in E:/incoming/temp/hb/Die Hard 4.0 (2007)_t00.mkv
AV sync in 1 at 0:00:00 (0ms) : 0 frame(s) dropped to reduce audio skew to +8ms
AV sync in 1 at 0:00:00 (8ms) : encountered overlapping frame, audio skew is +8ms
001003:0020 DEBUG: Code 0 at n\#}p`MV9XD.5{NB:29402279
001003:0020 DEBUG: Code 0 at *)sQF5!j965h>FtY#x;:121264556
001003:0020 DEBUG: Code 18 at kstXQhz>sC3xud$ta/Bp:29393286
001003:0020 DEBUG: Code 0 at =Vg37v50BDem9m'D){%:29396046
005003:0000 Failed to save title 0 to file E:/incoming/temp/hb/Die Hard 4.0 (2007)_t00.mkv
002023:0000 Encountered 11 errors of type 'Read Error' - see http://www.makemkv.com/errors/dvdread/
error=0x06031105 count=11 name=Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR
Encountered 6 unclassified errors
error=0xC000009C count=6 name=OS error - STATUS_DEVICE_DATA_ERROR
005004:0080 0 titles saved, 1 failed
Application exited at Mon Jul 15 13:13:45 2019
Grauhaar
Post by Grauhaar »
Looks like that the disc could not be read. Many Medium Errors and so on ....
Good Luck :)
Mr_Orange
Post by Mr_Orange »
Grauhaar wrote: Mon Jul 15, 2019 4:30 pm Looks like that the disc could not be read. Many Medium Errors and so on ....
Make MKV takes quite a long time to decide there is a disc and what is on it. It starts the rip and gets about 50% of the way through before quitting.
I have cleaned the disc but to no avail. Is there anything else I can try or this particular disc just not going to rip?
I do have an LG BH16NS55 BD drive on its way so will try again with that in case it is a drive issue.
Mr_Orange
Post by Mr_Orange »
Mr_Orange wrote: Mon Jul 15, 2019 11:22 pm
Make MKV takes quite a long time to decide there is a disc and what is on it. It starts the rip and gets a bit of 50% of the way through before quitting.
Same issues with the BD drive so it must be the disc itself.
