The Autopsy of Jane Doe (2016) BD (region B)
Nuitarius
Post by Nuitarius »
Hi
I am having issues with ripping this movie as the amount of playlists are overwhelming.
Does anybody know which segment order is the correct one or which mpls is the correct one?
Is there any way of detecting this on my own without trying each and every playlist and viewing the entire movie to see if the playback sequence is correct? It sure would take some time :D
Nuitarius
Marantz AV8802A, Emotiva XPA-2 GEN3, Emotiva XPA-4 GEN3, Emotiva XPA-5 GEN2
OPPO UD-203, NVIDIA Shield, Sonos Connect, Emby Movie server
2 B&W CM9, 1 B&W CMC2, 4 B&W CM5, 4 B&W CCM662, 1 Funk Audio 18.0
Re: The Autopsy of Jane Doe (2016) BD (region B)
Do you have the Java Runtime Environment (from java.com) installed, and did MakeMKV make a recommendation?
Nuitarius
Post by Nuitarius »
Woodstock wrote:Do you have the Java Runtime Environment (from java.com) installed, and did MakeMKV make a recommendation?
Hi
Yes I have java installed (version 8 update 131 at present moment) and I will go so far as saying no to your other question, as makemkv has all playlists ticked off.
hvnphoto
Post by hvnphoto »
The correct playlist for my version is 00006.mpls. If your copy does not yield that playlist take a look in the notes on which playlist is equal to 00006.mpls. That will be your answer.
Sorry, I no longer have the original BDMV file otherwise I would be able to tell you. Good luck.
