Correct .mpls for The Shack (2016)
Ssmonkey
Post by Ssmonkey » Wed May 24, 2017 5:55 pm
Does anyone happen to know the correct playlist for The Shack (2016)?
Damn playlist obfuscation...
hvnphoto
Re: Correct .mpls for The Shack (2016)
Post by hvnphoto » Wed May 24, 2017 7:04 pm
PLAYLIST REPORT:
hvnphoto
Post by hvnphoto » Thu May 25, 2017 1:06 am
Title information
Source file name: 00771.mpls
Duration: 2:12:19
Chapters count: 16
Segment count: 20
Segment map: 518,503,516,505,507,514,506,512,510,501,519,513,504,502,509,515,511,508,520,517
File name: The_Shack_t148.mkv
mattcoughlin
Post by mattcoughlin » Tue May 30, 2017 1:39 pm
my disc does not have a 771 playlist, or any segment map that starts with 518
bill2468
Post by bill2468 » Tue May 30, 2017 2:36 pm
Redbox "The Shack" does not have 0771 mpls. Any suggestions?
bretb
Post by bretb » Tue May 30, 2017 5:06 pm
hvnphoto wrote:Title information
Duration: 2:12:19
Chapters count: 16
Segment count: 20
The segment map is correct, no matter which *.mpls file it ends up being.
I have the RedBox disk also. If anyone knows the correct .mpls for that version, it would save us from having to search through so many.
bill2468
Post by bill2468 » Tue May 30, 2017 5:45 pm
I just checked and none of the mpls even start with 518 - they all start with 519. There are a lot of 519, 518, 502... combos. Still trying to find the right mpls - 0771 does not exist. Help appreciated!
hvnphoto
Post by hvnphoto » Tue May 30, 2017 7:06 pm
Sorry, if I had a copy of the Redbox version I can tell you the correct mpls. I have the Retail version. Since the audio is DTS-HD MA 5.1 on the Retail copy, I thought the Redbox copy would be the same. I guess not.
mattcoughlin
Post by mattcoughlin » Tue May 30, 2017 7:28 pm
how do you find the correct copy? process monitor even gives me a few hundred playlists.
hvnphoto
Post by hvnphoto » Tue May 30, 2017 8:08 pm
mattcoughlin wrote:how do you find the correct copy? process monitor even gives me a few hundred playlists.
Redfox AnyDVD HD application would be the fastest method if the physical disc is available. Otherwise, I would manually piece the segments together in 15 minutes.
TigerMoth
Post by TigerMoth » Tue May 30, 2017 8:13 pm
I'm willing to try piecing the segments together. How do I know which segments are correct, and in which order without AnyDVD?
hvnphoto
Post by hvnphoto » Tue May 30, 2017 8:26 pm
Within the BDMV folder there is a Stream folder. In the Stream folder you will see a number of m2ts files. These are the segment files for the movie. You will notice 00500.m2ts to 00520.m2ts, for example. Locate the first and last segments of the movie. In the case of The Shack (Redbox) the first segment is 518. Take a look at the end of the 518 scene. The end scene should flow into another segment of movie. Locate that segment and repeat. Eventually the movie will be complete as you piece the segments together. Hope this is clear.
TigerMoth
Post by TigerMoth » Tue May 30, 2017 9:10 pm
I'm willing to try piecing the segments together. How do I know which segments are correct, and in which order without AnyDVD?[/quote]
Within the BDMV folder there is a Stream folder. In the Stream folder you will see a number of m2ts files. These are the segment files for the movie. You will notice 00500.m2ts to 00520.m2ts, for example. Locate the first and last segments of the movie. In the case of The Shack (Redbox) the first segment is 518. Take a look at the end of the 518 scene. The end scene should flow into another segment of movie. Locate that segment and repeat. Eventually the movie will be complete as you piece the segments together. Hope this is clear.[/quote]
I can find all the files, but they are not decrypted, obviously, so won't play on VLC or anything else. How are you looking at the last scene, how are you decrypting the files, and what are you using to piece them together?
bretb
Post by bretb » Tue May 30, 2017 10:07 pm
bill2468 wrote:I just checked and none of the mpls even start with 518 - they all start with 519. There are a lot of 519, 518, 502... combos. Still trying to find the right mpls - 0771 does not exist. Help appreciated!
You are correct. My mistake.
Apparently they number the segments differently on each type of copy that they create (retail vs rental, etc.)
mattcoughlin
Post by mattcoughlin » Tue May 30, 2017 10:19 pm
i downloaded anydvd hd but i'm not sure how to use it to find the segment map or the right playlist
