[SOLVED 1.5.6 OSX] Application failed to initialize OSX
fumper
Post by fumper » Sun May 23, 2010 9:43 am
with the hopes of getting underway with HDDVD conversions i downloaded MKV this morning, but all i get is "Application failed to initialize"
is there something that i could be doing wrong? i wonder that this is only mentioned once on the forums and in the Windows part, thus my thinking goes to me doing something wrong, and not the program failing, anyone able to help?
macfrank
Re: Application failed to initialize OSX
Post by macfrank » Sun May 23, 2010 10:40 am
I got the same problem after updating to 1.5.6. No way to run makemkv after the update: application failed to initialize.
OS X 10.6.3
usul27
Post by usul27 » Sun May 23, 2010 12:03 pm
Same problem here
rjmusto
Post by rjmusto » Sun May 23, 2010 7:08 pm
Same for me. Updated to 1.5.6 and now fails to initialize. Running 10.6 SL
Any solutions guys?
joakes66
Post by joakes66 » Sun May 23, 2010 11:06 pm
:( same here. osx 10.6.3 and makemkv v1.5.6_beta
Claudio
Post by Claudio » Mon May 24, 2010 12:55 am
Same here. 1.5.6 failed to initialize on 10.6.3
freindlyfan
Post by freindlyfan » Mon May 24, 2010 2:40 am
Same here as well under OS 10.5.8. Makemkv 1.5.5 worked perfectly. Can I go back? I can't find a download.
c
rwurwin
Post by rwurwin » Mon May 24, 2010 4:18 am
Same here, Using OS X 10.6.3 MakeMKV 1.5.6 #FAIL
macfrank
Post by macfrank » Mon May 24, 2010 11:44 am
I downgraded to 1.54beta as I had another instance running on another Mac.
With 1.54beta it works again.
I cannot find downloads for previous versions too.
Hopefully the bug with 1.5.6beta will be fixed soon. It seems to be a generic problem on Mac with 10.5 and 10.6 OS X.
Please can this be fixed soon.
nilsga
Post by nilsga » Mon May 24, 2010 3:33 pm
I have the same problem. Would it be possible to make 1.5.5 available until this has been fixed?
macfrank
Post by macfrank » Mon May 24, 2010 3:41 pm
Would be great to offer 1.55beta for download again until the problem is fixed.
Shadow2k
Post by Shadow2k » Mon May 24, 2010 4:51 pm
Same problem here with 1.5.6. I've uploaded a crashlog to pastebin.org (http://www.pastebin.org/275067).
greetings :)
vinger
Post by vinger » Mon May 24, 2010 5:59 pm
I have the same problem since I've update to 1.5.6
Is it possible to return to 1.5.5 ?
Is it available ? and where ?
jcvalle
Post by jcvalle » Mon May 24, 2010 6:28 pm
I have encountered the same problem with 1.5.6, hopefully it will be fixed soon! I'm sure they're hard at work!
tobiaspb
Post by tobiaspb » Mon May 24, 2010 9:04 pm
Same here.
Here is a cache of older versions 1.5.5 works for me: http://www.videohelp.com/tools/MakeMKV/old-versions
- G
