The volume key is unknown for this disc - video can't be dec
lucacp
Post by lucacp »
"The volume key is unknown for this disc - video can't be decrypted"
Soooo what do I do/can be done?
PS: The ISO has the AACS folder
yorgo
Re: The volume key is unknown for this disc - video can't be
Post by yorgo »
/faq/item/11
There is no AACS key repository in MakeMKV for what you're trying to open. Recommend you try using the original disc.
ZXCDSA
Post by ZXCDSA »
yorgo wrote:http://www.makemkv.com/faq/item/11
(1) How do crate the AACS key repository please?
here it says
/faq/item/12
"First, you need to set an "AACS keys directory" in preferences; "
OK, downloaded MakeMKV 1.10.6 for Windose 7 Ultimate;
I have checked all the preferences tabs and its settings ,none of which mentions "AACS keys directory"
Placed an aacs.txt file to both target and working directories with no result.
(contents used from here: http://forum.doom9.org/showthread.php?t=120988)
yorgo wrote:Recommend you try using the original disc."
(2) I have purchased 3x Blu-Ray "Iron Man" discs in a video shop.
What am I doing wrong?
It is 2017 now and I cannot play EUR 50 blu-ray disc (import taxes here are huge) on a EUR 4k rig.
Ridiculous times.
I have no problems paying for a software as long as it works.
P.S. I have attempted to make MakeMKV from source on Debian 09 Stretch RC03, but got into dependecy hell, as following these instructions does not lead to any success:
http://www.makemkv.com/forum2/viewtopic.php?f=3&t=224
./configure --without--zlib
did not help.
Apparently need to use these blu-rays as a high quality expensive mirror for shaving in the morning. Will glue with a double sided 3M tape.
ZXCDSA
Post by ZXCDSA »
OK downloaded from here
http://www.labdv.com/aacs/KEYDB.cfg
placed in both MakeMKV installation directory +%%user%%/.MakeMKV
It's actually better to place such files in the MakeMKV data directory - which you set in Preferences->General. The data directory is not touched during installation of new versions, which isn't the case with the installation directory.
Mike REALLY needs to update that FAQ.
