Backup and further MakeMKV processing.
I searched Google and the forum for my answer, but did not find it. If I create a full disc Backup with MakeMKV, how do I open that Backup with MakeMKV for further processing into a MKV file? Thanks!
Re: Backup and further MakeMKV processing.
If you've burned the full disc backup to disc, simply load the disc and select it under MakeMKV, just as you would a commercial BluRay disc.
If you've saved it to a folder on your hard drive, start MakeMKV and click on the "Folder" icon, open the hard drive folder, click on the "BDMV" folder and select either the "index.bdmv" or "MovieObject.bdmv" folder...
