Things to Come (2016)
aecad
#1 Post by aecad » Tue May 09, 2017 11:47 pm
Ripping fails: Things to Come (2016) NetFlix DVD
MakeMKV v1.10.5 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\aecad/MakeMKV_log.txt
Calculated BUP offset for VTS #1 does not match one in IFO header.
Calculated BUP offset for VTS #2 does not match one in IFO header.
Calculated BUP offset for VTS #3 does not match one in IFO header.
Open DVD manually : "1"
Title #1 was added (12 cell(s), 1:41:37)
Saving 1 titles into directory F:/
DEBUG: Code 0 at B6a@/Gl}]*E9e:y0x:121262026
DEBUG: Code 450 at jnd2hl0#Hi!l8Y^*:UR:213136608
DEBUG: Code 0 at r]=Mk;I$b$1E&t>l}Ds#.:121267385
DEBUG: Code 0 at @\^pfsw+'GO/(,Fr|:121264211
DEBUG: Code 0 at @\^pfsw+'GO/(,Fr|:29395724
DEBUG: Code 0 at @\^pfsw+'GO/(,Fr|:121261980
LIBMKV_TRACE: Exception: Error in p->FetchFrames(2,true)
Failed to save title 0 to file F://title00.mkv
0 titles saved, 1 failed
Pioneer BD-RW BDR-208D / Intel i7-4770K / Windows 7 Ultimate (64 bit)
Re: Things to Come (2016)
#2 Post by Woodstock » Wed May 10, 2017 12:14 am
What happens if you allow MakeMKV to open the disk automatically?
It is possible that the manual choice points to an invalid collection of chapters. It's also possible that there is an error in the directory structure, either from a disk defect or something as simple as a fingerprint.
Please follow the steps in the FAQ link in my signature, and send the requested information to support@makemkv.com so that Mike can look at it. At the very least, it will help with recognizing the disk automatically.
aecad
#3 Post by aecad » Wed May 10, 2017 1:04 am
Thanks for the reply.
Woodstock wrote:What happens if you allow MakeMKV to open the disk automatically?
When auto failed I tried manual to verify.
...send the requested information to support@makemkv.com...
I will do that.
It's interesting that both DVDDecrypter and DVDFab10 are successful in extracting the DVD folders, but MKV tries on both also resulted in fails. Atm I've got DVDFab10 trying a MKV/H256 rip directly off the DVD, just to see...
[Update] Data sent. Also, DVDFab10 will successfully create a .mkv file in pass-thru mode. I have not completely viewed it yet but the film timing matches the DVD and file size matches what MKV had reported.
