[SOLVED 1.5.6 OSX] Application failed to initialize OSX
fumper
with the hopes of getting underway with HDDVD conversions i downloaded MKV this morning, but all i get is "Application failed to initialize"
is there something that i could be doing wrong? i wonder that this is only mentioned once on the forums and in the Windows part, thus my thinking goes to me doing something wrong, and not the program failing, anyone able to help?
macfrank
Re: Application failed to initialize OSX
I got the same problem after updating to 1.5.6. No way to run makemkv after the update: application failed to initialize.
OS X 10.6.3
OS X 10.6.3
usul27
Same problem here
rjmusto
Same for me. Updated to 1.5.6 and now fails to initialize. Running 10.6 SL
Any solutions guys?
Any solutions guys?
joakes66
Claudio
Same here. 1.5.6 failed to initialize on 10.6.3
freindlyfan
Same here as well under OS 10.5.8. Makemkv 1.5.5 worked perfectly. Can I go back? I can't find a download.
c
c
rwurwin
Same here, Using OS X 10.6.3 MakeMKV 1.5.6 #FAIL
macfrank
I downgraded to 1.54beta as I had another instance running on another Mac.
With 1.54beta it works again.
I cannot find downloads for previous versions too.
Hopefully the bug with 1.5.6beta will be fixed soon. It seems to be a generic problem on Mac with 10.5 and 10.6 OS X.
Please can this be fixed soon.
nilsga
I have the same problem. Would it be possible to make 1.5.5 available until this has been fixed?
macfrank
Would be great to offer 1.55beta for download again until the problem is fixed.
Shadow2k
Same problem here with 1.5.6. I've uploaded a crashlog to pastebin.org (http://www.pastebin.org/275067).
greetings
greetings
vinger
I have the same problem since I've update to 1.5.6
Is it possible to return to 1.5.5 ?
Is it available ? and where ?
jcvalle
I have encountered the same problem with 1.5.6, hopefully it will be fixed soon! I'm sure they're hard at work!
tobiaspb
Same here.
Here is a cache of older versions 1.5.5 works for me: http://www.videohelp.com/tools/MakeMKV/old-versions
- G
- G
