Best way to move MakeMKV to another drive?
jkauff
Post by jkauff »
My C: drive is an M.2 NVMe SSD, and I think it's throttling from the heat when I convert a very large Blu-ray. I have another drive I'd like to move MakeMKV to, but it's a licensed copy and I'm not sure how to do it and retain the license info.
Any advice?
Re: Best way to move MakeMKV to another drive?
Post by d00zah »
Pretty sure moving the app itself will not change anything, but you could try changing where MakeMKV output is written?
Options > Video tab > Default destination > SemiAuto
& set an alternate output path (to the other drive).
jkauff
Post by jkauff »
d00zah wrote:Pretty sure moving the app itself will not change anything, but you could try changing where MakeMKV output is written?
Thanks, but I'm already using an alternate path for output. Still have the problem.
Post by d00zah »
Fair enough... I still doubt it'll matter, but if your key is not written down, you can recover it from the current install buy accessing Help > Register & copy/pasting current key to a safe location. Then you can uninstall/reinstall/re-register anywhere you wish.
jkauff
Post by jkauff »
d00zah wrote:Fair enough... I still doubt it'll matter, but if your key is not written down, you can recover it from the current install buy accessing Help > Register & copy/pasting current key to a safe location. Then you can uninstall/reinstall/re-register anywhere you wish.
Thanks. That's the answer I was looking for.
On further thought, however, I probably need to change the temp file location to another drive. Wonder if I can do that in the registry or if the default is hard-coded?
I don't think MakeMKV bothers with a temporary file, though.
jkauff
Post by jkauff »
Well, for whatever reason, moving the MakeMKV application allows me to rip the title with no slowdown. It was a very big title, over 40GB, and it would bog down at around 34GB read.
