Fargo Season 1
cojacket
Fargo Season 1
Post by cojacket » Wed Apr 26, 2017 7:06 pm
I am unable to make mkv's of Fargo Season 1 Episodes 7, 9, and 10. I am getting read errors. I have cleaned the disks and tried manual dvd scanning none of which worked.
Any suggestions much appreciated.
OS device name: E:
Current profile: DVD-ROM
Manufacturer: hp
Product: BDDVDRW CT10L
Revision: YC09
Serial number: K0Z9B1D3853
Firmware date: 2009-06-04 12:34:56
Highest AACS version: 15
Disc Information
Label: FARGO_SEASON_1
Timestamp: 2014-07-30 11:25:40
Data capacity: 7.62 Gb
Disc type: DVD-ROM
Disc size: 120mm
Maximum read rate: 10.08 Mbps [1x]
Number of layers: 2 (OTP)
Re: Fargo Season 1
Post by Woodstock » Wed Apr 26, 2017 8:11 pm
It would be helpful to know what errors you're receiving. And if they always occur at the same place, or if they move around.
cojacket
Re: Fargo Season 1
Post by cojacket » Wed Apr 26, 2017 9:36 pm
Woodstock wrote:It would be helpful to know what errors you're receiving. And if they always occur at the same place, or if they move around.
Here's the error log.
MakeMKV v1.10.5 win(x64-release) started
Open DVD manually : "2"
Title #2 was added (16 cell(s), 0:44:20)
Encountered 1 errors of type 'Read Error' - see /errors/dvdread/
Saving 1 titles into directory C:/Users/Harold/Videos/Handbrake
Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while reading '/VIDEO_TS/VTS_05_1.VOB' at offset '501760'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom1' at offset '501760'
AV synchronization issues were found in file 'C:/Users/Harold/Videos/Handbrake/title00.mkv' (title #1)
AV sync issue in stream 1 at 0:17:38.368 with duration of 356.333ms : audio gap - 11.135 missing frame(s)
Failed to save title 0 to file C:/Users/Harold/Videos/Handbrake/title00.mkv
Encountered 11 errors of type 'Read Error' - see /errors/dvdread/
0 titles saved, 1 failed
Here's a url to the IFO file and debug log
cojacket
Re: Fargo Season 1
Post by cojacket » Wed Apr 26, 2017 10:46 pm
Here's the IFO files and the full debug log.
https://drive.google.com/file/d/0B61Kca ... sp=sharing
