Failed to open disk
brellyn
Failed to open disk
Post by brellyn »
MakeMKV v1.10.5 win(x64-release) started
Title #00102.mpls has length of 287 seconds which is less than minimum title length of 5555 seconds and was therefore skipped
... deleted 17 more "skipped" titles for brevity ...
Title #00012.m2ts has length of 180 seconds which is less than minimum title length of 5555 seconds and was therefore skipped
OS device name: E:
Manufacturer: PIONEER
Product: BD-RW BDR-209D
Revision: 1.34
Serial number: (removed)
Firmware details: intf=SAT gen=8600 krnl=ID61 main=ID61 ver=0000
Firmware date: 2016-04-25
Bus encryption flags: 13
Highest AACS version: 46
Disc Information
Label: COLD_COMES_THE_NIGHT
Timestamp: 2014-01-11 11:34:39
Data capacity: 26.3 Gb
Disc type: BD-ROM
Number of layers: 2
This identical failure is on two different computers with two different bluray drives. This movie plays in it's entirety and I can use windows to copy every file onto my hard drive without issue. So the disk appears to be completely readable, but MakeMKV 1.10.5 returns the "Failed to open disk" error.
:shock:
Re: Failed to open disk
How long is the movie? You've told MakeMKV to not look at any title shorter than 92:45 seconds. If no title is at least that long, you'll get the "failed to open disk".
brellyn
Post by brellyn »
The movie is 90 minutes long. Changing minlength to 5000 from 5555 solved the problem. Thank you :)
Wouldn't "no titles match the minimum defined length" be a bit less confusing?
Yes, it probably would be a LOT better.
But I have no control over that. You might want to post it as a suggestion for Mike.
