La La Land
hvnphoto
La La Land
Post by hvnphoto »
U.S. Retail
Title information
Name: La La Land
Source file name: 00620.mpls
Duration: 2:07:48
Chapters count: 16
Segment count: 15
Segment map: 509,512,506,501,515,505,502,507,504,503,508,510,514,511,513
File name: La_La_Land_t134.mkv
Redbox and Netflix will be different since it doesn't include the TrueHD 7.1 Atmos.
UsedKondomXL
Re: La La Land
Post by UsedKondomXL »
Thanks.
wieas1070
Re: La La Land
Post by wieas1070 »
Any info about Redbox version? Tanks.
mikesnav
Re: La La Land
Post by mikesnav »
wieas1070 wrote:Any info about Redbox version? Tanks.
Did you figure it out?
pleiosaur
Re: La La Land
Post by pleiosaur »
̶H̶i̶ ̶g̶u̶y̶s̶,̶ ̶l̶o̶o̶k̶s̶ ̶l̶i̶k̶e̶ ̶0̶0̶4̶1̶6̶.̶m̶p̶l̶s̶ ̶i̶s̶ ̶t̶h̶e̶ ̶c̶o̶r̶r̶e̶c̶t̶ ̶o̶n̶e̶ ̶f̶o̶r̶ ̶r̶e̶d̶b̶o̶x̶.̶ ̶ ̶ ̶
S̶e̶g̶m̶e̶n̶t̶ ̶m̶a̶p̶:̶ ̶5̶0̶5̶,̶3̶0̶0̶6̶,̶5̶0̶3̶,̶5̶0̶2̶,̶5̶0̶7̶,̶5̶0̶9̶,̶5̶0̶4̶,̶5̶0̶8̶,̶5̶1̶0̶,̶5̶0̶6̶,̶5̶0̶1̶ ̶ ̶
H̶a̶v̶e̶n̶'̶t̶ ̶v̶e̶r̶i̶f̶i̶e̶d̶ ̶i̶t̶ ̶y̶e̶t̶ ̶b̶y̶ ̶w̶a̶t̶c̶h̶i̶n̶g̶,̶ ̶b̶u̶t̶ ̶i̶t̶ ̶a̶p̶p̶e̶a̶r̶s̶ ̶t̶o̶ ̶b̶e̶ ̶t̶h̶e̶ ̶c̶o̶r̶r̶e̶c̶t̶ ̶o̶n̶e̶.̶ ̶I̶ ̶t̶h̶i̶n̶k̶ ̶t̶h̶e̶y̶ ̶h̶a̶v̶e̶ ̶g̶o̶t̶t̶e̶n̶ ̶c̶r̶e̶a̶t̶i̶v̶e̶ ̶a̶n̶d̶ ̶t̶h̶a̶t̶ ̶m̶p̶l̶s̶ ̶m̶a̶y̶ ̶n̶o̶t̶ ̶s̶h̶o̶w̶ ̶u̶p̶ ̶w̶h̶e̶n̶ ̶y̶o̶u̶ ̶o̶p̶e̶n̶ ̶t̶h̶e̶ ̶d̶i̶s̶c̶.̶ ̶L̶e̶t̶ ̶m̶e̶ ̶k̶n̶o̶w̶ ̶i̶f̶ ̶t̶h̶a̶t̶'̶s̶ ̶t̶h̶e̶ ̶c̶a̶s̶e̶,̶ ̶a̶n̶d̶ ̶I̶ ̶t̶h̶i̶n̶k̶ ̶I̶ ̶f̶i̶g̶u̶r̶e̶d̶ ̶o̶u̶t̶ ̶a̶ ̶w̶o̶r̶k̶a̶r̶o̶u̶n̶d̶.̶
Scratch that. Not the right mpls...
thecrusher
Re: La La Land
Post by thecrusher »
hvnphoto wrote:U.S. Retail
Title information
Name: La La Land
Duration: 2:07:48
Chapters count: 16
Segment count: 15
This doesn't appear to be correct for the Best Buy exclusive steelbook version. The segment map for 620 is different.
Title information
Name: La La Land
Duration: 2:07:48
Chapters count: 16
Segment count: 15
Segment map: 509,503,513,514,504,515,502,501,507,506,511,512,510,505,508
File name: La_La_Land_t255.mkv
mikesnav
Re: La La Land
Post by mikesnav »
Hi guys, looks like 00416.mpls is the correct one for redbox.
Segment map: 505,3006,503,502,507,509,504,508,510,506,501
Haven't verified it yet by watching, but it appears to be the correct one. I think they have gotten creative and that mpls may not show up when you open the disc. Let me know if that's the case, and I think I figured out a workaround.
Will try 416 this afternoon, thanks!
forumuser599
Re: La La Land
Post by forumuser599 »
Redbox Version
Title information
Name: La La Land (English)
Source file name: 00912.mpls
Duration: 2:07:48
Chapters count: 16
Segment count: 10
Segment map: 505,502,503,510,506,504,501,507,509,508
File name: La_La_Land_t205.mkv
Verified by watching. This is the correct segment map, but if your .mpls is not 912, you'll have to find the one that matches this segment map.
pleiosaur
Re: La La Land
Post by pleiosaur »
Okay, seems like they had a decryption catch or something on the disc. Thinking 33.mpls may be the right one... Trying now.
forumuser599
Re: La La Land
pleiosaur wrote:Okay, seems like they had a decryption catch or something on the disc. Thinking 33.mpls may be the right one... Trying now.
check my post above, it's correct for the Redbox version
pleiosaur
Re: La La Land
Post by pleiosaur »
Awesome thank you! Just curious, what method did you use to get the correct mpls? My tried and true ones didn't seem to work this time.
Crtguy
Re: La La Land
Post by Crtguy »
Netflix is also 912-same segment map.
dholme
Re: La La Land
Post by dholme »
Title information
Name: La La Land
Duration: 2:07:48
Chapters count: 16
Segment count: 15
This appears to be incorrect for the US Retail disc at Target also (the standard release not the Target exclusive version).
U.S. Retail standard version at Target
Title Information
Duration: 2:07:48
Chapters count: 16
Segment count: 15
Segment map: 512,515,504,506,503,507,502,505,509,510,514,501,513,508,511
File name: La_La_Land_t248.mkv
mkvgrub
Re: La La Land
Post by mkvgrub »
Crtguy wrote:Netflix is also 912-same segment map.
Thanks to you & all
TheNid
Re: La La Land
Post by TheNid »
Hmm. My Redbox is only showing me 00416.mpls as a possibility. 00912.mpls is showing as only 10 seconds long.
