I'm new to MakeMKV, but I'm ripping DVD and Blurays that have DTS forms of audio, and I'm using FLAC. They all seem to have AV out of sync slightly.
Is there an adjustment or setting I can make to fix this? I'm using the latest Beta version of the program on a Mac.
I should also mention I'm using PLEX to view the MKV files.
Thanks for your help!
Newbie Question About AV Sync for DTS/DTS-MA
LCubed
Re: Newbie Question About AV Sync for DTS/DTS-MA
Here's an update. I just used VLC to play the video on my Mac, and there is no sync issue.
Is it fair to assume the problem lies with Plex?
I'm using a Synology DS416play as my Plex server, viewing the content on a Roku all on my 1GB LAN.
It is possible, but USUALLY in situations like this, the video lags the audio. The question is whether or not Plex is having an issue converting the lossless data stream for the Roku, or the Roku is having an issue playing it.
Do you have another device that can access the plex server?
