1.10.5 no longer mapping to network drives
notfrench
Post by notfrench »
Previous versions of the software on Windows 10 were able to detect network drive mappings. Now however that option has been either disabled or missing. Is there any way to bring this feature back?
Re: 1.10.5 no longer mapping to network drives
Please clarify the question.
I'm using 1.10.5 ripping to a NAS, but I'm doing so under Win7. As a test, I'm ripping to the raw share right now, rather than through the normal mapped drive, and it is proceeding normally.
It may be that you have an issue with your Win10 networking configuration, or permissions.
brellyn2
Post by brellyn2 »
Me ripping to my N: NAS drive on windows 10 latest MakeMKV.
https://ibb.co/cgCU1Q <---
nscelica
Post by nscelica »
Same issue. I had a windows mapping to Z:, and the path used to be Z:\Uncompressed, now I need to manually put in the network path. Not a huge deal, but its something that depreciated. I upgraded to the Windows 10 Creators Edition, but the last version worked on that version of Windows with the network drive. This version doesn't. Wonder if its a combo of both.
ThePlayerOfGames
Post by ThePlayerOfGames »
This appears to be the case in 1.10.6 too - the NAS drive I have used as output is not visible in the available drives listing in the Output folder, and does not accept the location when manually entered.
The drive is visible and accessible in Explorer.
It's not the end of the world, but it would be a nice fix to have.
ThePlayerOfGames
Scratch that - restarting the application seems to have fixed it
