Navigation Error causes Movie to be Skipped
kahomono
Post by kahomono » Mon Apr 10, 2017 11:01 am
Trying to copy Black Hawk Down to MKV, I get
Debug log started at Mon Apr 10 10:52:03 2017 , written by MakeMKV v1.10.5 linux(x64-release)
001005:0000 MakeMKV v1.10.5 linux(x64-release) started
001004:0000 Debug logging enabled, log will be saved as /home/david/MakeMKV_log.txt
003024:1000 Complex multiplex encountered - 31 cells and 17283 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
001003:0020 DEBUG: Code 100864261 at ,Ak{f8v^6UW_q[BD:121269731
001003:0020 DEBUG: Code 845756 at yWScK|&?/R3i!xM9:121263383
001003:0020 DEBUG: Code 0 at tN<p4$HV!-YEW/#y;X:121273457
001003:0020 DEBUG: Code 0 at tN<p4$HV!-YEW/#y;X:29406879
003015:0000 Title #1 (2:24:12) was skipped due to navigation error
Title skip vts=1 pgcn=1 hash=9482F9597AD01531
003024:1000 Complex multiplex encountered - 2 cells and 300 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
003028:0000 Title #2 was added (2 cell(s), 0:02:32)
003024:1000 Complex multiplex encountered - 2 cells and 291 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
003028:0000 Title #3 was added (2 cell(s), 0:02:23)
003024:1000 Complex multiplex encountered - 2 cells and 2882 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
003028:0000 Title #4 was added (2 cell(s), 0:24:01)
001003:0020 DEBUG: Code 0 at R&AW69*m$W0vCyK7wTOp-5N:213130122
001003:0020 DEBUG: Code 233 at Kof1sqgdOGfuyYzmxAnnJ4Ka:0
Application exited at Mon Apr 10 10:59:28 2017
So this means I can get the "special features" (which I usually archive or just discard), but not the actual movie to put into PLEX.
Any suggestions?
Re: Navigation Error causes Movie to be Skipped
Post by Woodstock » Mon Apr 10, 2017 12:50 pm
"The old standby" of cleaning the disk comes to mind, because it found 6 different bits of weirdness reading the VOBs (the debug codes issued) for the main feature. Any one of them could cause the data to point outside the addressable range of the disk, i.e., a "navigation error".
kahomono
Post by kahomono » Mon Apr 10, 2017 1:50 pm
Woodstock wrote:"The old standby" of cleaning the disk comes to mind, because it found 6 different bits of weirdness reading the VOBs (the debug codes issued) for the main feature. Any one of them could cause the data to point outside the addressable range of the disk, i.e., a "navigation error".
Should have mentioned, that was the 1st thing I tried.
Post by Woodstock » Mon Apr 10, 2017 3:48 pm
I'd suggest seeing if an older version has the same issue; recent past versions can be downloaded from /download/old
Black Hawk Down has been ripped by others before, so, barring a defective disk this might be a bug in 1.10.5.
