Bizarre error message
mitch30
Post by mitch30 » Sun Apr 09, 2017 3:34 pm
Just downloaded latest version of Make MKV for Mac: 1.10.5. However when I try to open it it informs me that this version is too old and asks me either to download latest or to provide registration code. Please clarify.
I run a MacPro under OSX 10.11.6, El Captain.
Re: Bizarre error message
Post by Woodstock » Sun Apr 09, 2017 6:07 pm
Did you have a previous version installed?
There have been reports on other forums (different software) that the latest MacOS would not allow software to install updates, so the previous version remained installed.
mitch30
Post by mitch30 » Sun Apr 09, 2017 6:55 pm
Thanks for the reply.
I do not have a previous version installed. However, after several tries, Make MKV did open in the advertised version, 1.10.5. Bizarre behavior, but now running well.
For your information, the version of the Mac OS I run is not the latest version.
steinmb
Evaluation period has expired, shareware (Bizarre error mess
Post by steinmb » Fri Apr 14, 2017 2:57 pm
Mine also does this:
MakeMKV v1.10.5 darwin(x86-release) started
Evaluation period has expired, shareware functionality unavailable.
No idea how to fix this. Any suggestions?
Post by Woodstock » Fri Apr 14, 2017 10:25 pm
USUALLY, re-entering the current beta key will restart the 30 day clock.
Or buying a permanent key.
