Errors ripping Breaking Bad blu-rays
theimmortalbum
Post by theimmortalbum » Sun Apr 02, 2017 8:02 pm
Hi. I'm having a heck of a time ripping my Blu-ray disks of Breaking Bad. I have the collector's set, and my season 1 disks worked fine. Episode 8 (so the second disk) of season 2 is having issues, and it's a similar story with disk 3. I'm attempting to rip that episode again to get the debug log to post, but figured I'd go ahead and post to see if this is a known issue for these particular disks? In addition to having hash failures on the media, the first time I put in disk 2 of this season, it took MakeMKV maybe 15 minutes to even open the disk.
Edit: Should note, to rule out drive failure, I popped in another Blu-ray I've successfully ripped before and it opened and ripped just fine.
Edit 2: attached debug log.
Edit 3: I actually can't? Whatever. Here's a gist of it.
https://gist.github.com/tjsimmons/153be ... c290cd5be4
yorgo
Re: Errors ripping Breaking Bad blu-rays
Post by yorgo » Tue Apr 04, 2017 10:59 am
I have successfully ripped this series. I also had a problem with one or two of the discs but after replacing, ripped fine. If you were able to successfully rip another disc, I'd suggest cleaning the one that doesn't rip with mild soap and water thoroughly and, if that doesn't work, replacing.
http://www.makemkv.com/forum2/viewtopic.php?f=8&t=15055
