Some Blu Ray Disks Will not Rip Right (pixelated)
localguy
Post by localguy » Mon Apr 03, 2017 3:22 am
I have ripped almost all of my library to played on a Raspberry PI that is connected to my TV. My movies are on an powered external disk that is directly connected to the Raspberry PI.
I have noticed that some of my Blu Ray movies are "pixelated" (if that is the correct term). The playback is slow and seems stuck for a second or two, them will show large "pixels" . The sound is perfect.
I noticed this on Blade Runner (Five-Disc Complete Collector's Edition) [Blu-ray], and all of the disks of the The Bourne Classified Collection. The disk are all new and play correctly in my Blu Ray player. This may have happened on other disks but I have not noticed. The disks are clean, the Bourne disks are brand new. Other Blu Ray disks have been ripped and play with out issue.
What could be causing these issues?
Phil J
Re: Some Blu Ray Disks Will not Rip Right (pixelated)
Post by Woodstock » Mon Apr 03, 2017 3:33 am
Insufficient processing power in the RPi to decode the codec, or issues with getting the file into the decoder. I think the RPi has a hardware h.264 decoder built into it, but it probably doesn't handle VC-1 in hardware. And it may not be able to read the disk fast enough for high bit rates on USB2.
MakeMKV can decode the Bladerunner series just fine, so it should not be an issue with BD+ decode issues. But what you describe is classic "I'm overwhelmed trying to decode this video, so I'll keep the audio going what I try to catch up".
trumpet205
Post by trumpet205 » Mon Apr 03, 2017 7:45 pm
Woodstock wrote:Insufficient processing power in the RPi to decode the codec, or issues with getting the file into the decoder. I think the RPi has a hardware h.264 decoder built into it, but it probably doesn't handle VC-1 in hardware. And it may not be able to read the disk fast enough for high bit rates on USB2.
Pi DOES have VC-1 hardware decoder, but you MUST buy separate license for it. Same with MPEG2.
http://www.raspberrypi.com/license-keys/
You must have these license keys or else Pi will struggle trying to decode these videos on software mode.
